Engine removal
Old Mar 18, 2009 | 04:42 PM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Originally Posted by jimmyb496
Now I'm intimidated. I just wanted to pull the motor out and send the heads out to be ported and throw a cam in it, & upgrade the clutch. Pulling the driveline out from the bottom looks like a chore! Is there a book availible for C6's on w/ procedures, etc on some of this? I'm gonna feel so alone out there
I just did it in my garage and it only took me 5 hours from start to finish. PM me and I'll send you my phone number to explain the process.
Christopher
Old Mar 18, 2009 | 04:43 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Question?
If you pull it out the top, does that save a front end alignment?
Dropping it out the bottom is a sure thing for a front end alignment.
Elmer
Old Mar 18, 2009 | 04:46 PM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
when you pull from the top you are not changing or removing anything that would alter your aligment!!!!!
the frame stays in the car bolted up, you simply remove the mounts from the subframe
thesubfloor
Originally Posted by eboggs_jkvl
Question?
Elmer
Since you still need to lower the front cradle even while taking it out from the top, my guess is that you probably will need an alignment.
Old Mar 18, 2009 | 04:48 PM
thesubfloor
You must have done it slightly differently than I did as I dropped the cradle in order to have the harmonic balancer clear everything.
Old Mar 18, 2009 | 05:49 PM
pmj341's Avatar
pmj341
I had no problem at all clearing the rack or radiator, I did remove water pump and all acc's
and removed the A/C compressor bolts and stud just prior to rotating for clearance.
and went back the same, I did remove the engine mounts from the engine and subframe.
Old Mar 18, 2009 | 05:53 PM
thesubfloor
I didn't remove anything other than the AC compressor.
Six of one I guess...
Old Mar 18, 2009 | 05:56 PM
pmj341's Avatar
pmj341
it's just what I was used to, I'm oldschool!!!! don't know the ways of the world
Time wise it took me 2 hrs out and 3 back, doing things in order and taking my time.
Old Mar 18, 2009 | 08:36 PM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Anytime you drop the cradle you need to get an alignment. I thought I had all my ducks in order by marking the position of the bolts on the suspension (mark the adjustment bolt/washer and the suspension and make sure you place the front suspension spacers in the same place)....... and yet it still needed to be adjusted on the alignment rack......go figure
Old Mar 18, 2009 | 09:59 PM
david srour's Avatar
david srour
is it best to take off intake to avoid damage from chains? thanks
Old Mar 18, 2009 | 10:06 PM
thesubfloor
I left the intake on and didn't have any problems.
Old Mar 19, 2009 | 01:28 PM
pmj341's Avatar
pmj341
I do!!!
it's up to you
Old Mar 19, 2009 | 01:57 PM
  #33
david srour
Agree. It seems like from most of pictures intake is off durinf shoehorning. Not hard to put on when in the car, so makes sense.
thanks
Old Apr 6, 2009 | 05:00 PM
  #34
jimmyb496's Avatar
jimmyb496
We'll, here we go. I pulled the driveline out from the bottom. Now just have to do the upgrades and put it all back together. One thing that slowed us down a little is the wiring harness. We started disconnecting all the fuel injectors and component wire plugs. Once it really started to get tideous and had to pull headers and starters and still wasn't sure how to get the harness through the drivers side of the engine. We stopped and thought about a different approach. I ended up tracing the engine harness down to the computer in the fender behind the passenger side front tire. Marked and disconnected the 2 connectors and traced one other harness to the fuse box on top of the pass wheel well and removed it. After that all the engine wire harnesses came out with the engine assembly. Here's a pic of the hardware out the bottom. Thanks for the above pictures, they provided a great reference (and moral support, lol)
http://videos.streetfire.net/photo/906JPG_1657630.htm
Old Jun 28, 2009 | 02:20 AM
  #35
jimmyb496's Avatar
jimmyb496
Thanks all for the excellent thoughts and info posted here a couple months back. My buds, Ian, Julian (2Lane Performance who did the engine work) and I just finished putting the driveline back in the car and I took it for a quick ride. Just making sure the new clutch is working, gauges look good, and nothing is leaking. The thing sounds pretty sweet.
I'll post the video tomorrow. The engine now has some seriously good flowing 243 heads ported by Total Airflow and a Vengence VRX5 cam. Vengence also supplied the FAst 92 intake.
The combo won't idle yet and it's either running very lean or very retarded.. the headers started to glow holding the rpm's at 2500. It's going to J&M Motorsports in CT on Thursday to dial in the tune for all the new inurds. Can't wait to drive it "for real" when everything is running smooth.
