New FAST?
Old Jan 22, 2009 | 01:50 PM
Isaiah48's Avatar
Isaiah48
Default New FAST?
I thought I read somewhere in here that FAST was coming out with a new intake, any idea when that might be and if any testing has been done as yet?
I need an good intake bad, I'm sure my ported stock intake is a choke point...
Old Jan 22, 2009 | 02:15 PM
dennis50nj's Avatar
dennis50nj
for the LS3
Old Jan 22, 2009 | 03:17 PM
LS1LT1's Avatar
LS1LT1
Originally Posted by dennis50nj
for the LS3
True, the new one (102mm) coming out is for the LS3 motors/heads (rectangle port heads versus the LS2's cathedral ports).
You can buy the current 92mm FAST intake that's already available right now for your car (unless your Stage III heads are actually L92s/LS3s?) if you want it. It works too.
Old Jan 23, 2009 | 09:04 AM
Isaiah48's Avatar
Isaiah48
The Stage III heads I have are just the stock castings with bigger valves, porting and milled .030 It might be time to build some L92's though. I want to build a stroker next year anyway and they will flow better than mine. I'll have to ponder this awhile...
To New FAST?
