Sway bar questions
Old Jan 26, 2009 | 04:20 PM
Homer3D's Avatar
Homer3D
Default Sway bar questions
I used the search but really couldn't find the answer.
I have a 2005 C6 w/ Z51 and I am looking at 2 sway bars:
C6 Hotchkis Corvette Sway Bars @ $430
Pfadt C6 Street Sway Bars @ $850
I don't reallly know the difference between the 2. I know the Pfadt is adjustable, but other than that is there anything else about the Pfadt that makes is so much better to be almost double the price?
I also found that people are saying the Z51 sway bars with the Pfadt C6 Z51 Poly Sway Bar Bushings ($30) is a great upgrade. Anyone do this? Does replacing just the bushings for $30 make a dramatic improvement in the handling? I have a future upgrade to Pfadt C6 Adjustable Inverted Sport Shocks coming as well.
What are your thoughts?
Old Jan 26, 2009 | 04:29 PM
Silverspeed's Avatar
Silverspeed
St. Jude Donor '13, '15
Not really on-topic but where are you getting the Hotchkis bars for 430?
Old Jan 26, 2009 | 04:36 PM
Homer3D's Avatar
Homer3D
Just about anywhere.
http://www.corvettegarage.com/produc...-corvette.html
http://www.westcoastcorvette.com/p-1...sway-bars.aspx
Old Jan 26, 2009 | 04:42 PM
miami08VETTE's Avatar
miami08VETTE
got my Hotchkis sways from LAPD, a forum vendor, for under $400. They are excellent sways, very effective and don't cost an arm and a leg. I have used them on 2 previous cars and have always been happy with them. The rears are adjustable by the way, the front is not.
I have a Z51 equipped coupe and these made a marked impact on flatter cornering and a much more planted feel in high speed curves.
Old Jan 28, 2009 | 04:13 PM
Aaron Pfadt's Avatar
Aaron Pfadt
St. Jude Donor '08
Autocross & Roadrace Forum Sponsor
Homer,
The main functional difference between the two sets is that our 'Street' bar setup has a lot more rate than the Hotchkis setup. The Hotchkis setup is in the ballpark of the Z51 setup in terms of rate. Our Pfadt Street kit spans from about 50% stiffer to 100% stiffer than the Z51 package (depending on where you have them adjusted). This is important because as GM has updated the Corvette they have followed a trend of continually increase sway bar rate. Basically the increase in roll stiffness adds performance without sacrificing ride quality. This is why our Street package has such a firm rate.
Our bars are also adjustable in both the front and rear which gives you more ability to tune to different tire combos and suspension setups. The other main difference is weight. With the hollow tube and 7075 aluminum arms our bars weigh less than a bent steel bar.
Hope this helps. Give a call if you have any questions on our package.
-Aaron
Old Jan 29, 2009 | 11:59 AM
Homer3D's Avatar
Homer3D
Thanks for the info. I guess at this point it really just come down to price vs performance. I am basically a street guy with occasional autox-ing. So I am just looking for the best bang for the buck.
To Sway bar questions
