Valve Piston Interference Pictures
Old Jan 28, 2009 | 02:34 PM
gath47's Avatar
gath47
Default Valve Piston Interference Pictures
This is what a timing chain failure will do to your pistons...
This is probably the worst impact. After inspecting all of them closely with high resolution pictures I did not find any signs of cracks or other failures. I am considering getting a penetrant dye kit, but am not sure how much value that will add. Who has actually reused stock pistons that look like this?
Here are the before and after pictures of the cleaning. Shiny!
Old Jan 28, 2009 | 03:03 PM
adam205348's Avatar
adam205348
If you use the dye kit to check for cracks and there are none, I suppose they would be fine to reuse but if you have the extra cash i would go for new and perferably forged pistons. What is your setup? In past motors yes I have rused pistons that have had contact with the valves after having them checked for cracks. Put this was also Forged pistons in a Old School Big Block Chevy not hypereutectic pistons in a new school small block.
Old Jan 28, 2009 | 03:23 PM
1.8t's Avatar
1.8t
Welcome to the party. Many of my pistons looked similar but I did have a couple with complete circles on them. FWIW, I am rolling the dice and re-using mine and I am even leaving the cam in the car. Guess we will get to see how they hold up to ~480whp(not sure how much the new setup will make since I am going back to the stock balancer....old setup made 483whp).
Old Jan 28, 2009 | 03:28 PM
gath47's Avatar
gath47
Ported heads, 228/232 cam, headers, 425rwhp. The stock pistons should be fine for this application. I'm not really looking to upgrade, nor would that be an economical alternative.
Does anyone have a dye kit that they have actually used and recommend?
Old Jan 28, 2009 | 03:32 PM
gath47's Avatar
gath47
Haven't seen much activity from you lately, I was wondering what the latest news was on your rebuild? Did you do a dye check on them? Have you started to put things back together?
Old Jan 28, 2009 | 04:00 PM
adam205348's Avatar
adam205348
To me this is the only one to use.
http://www.pegasusautoracing.com/gro...upID=CRACKTEST
Old Jan 28, 2009 | 04:02 PM
1.8t's Avatar
1.8t
Yes, things are already going back together. I did not dye check them as I feel confident enough *knocks on wood* that they are fine. I have already gotten the front part of the motor buttoned back up, the stock balancer back on, a/c and radiator back in. I get my heads back today or tomorrow at which point I will re-assemble them with the new valves and valvesprings and that is when the "real" work will begin. I have all of my parts, the heads are the only item I am waiting on.
Old Jan 29, 2009 | 01:45 AM
glass slipper's Avatar
glass slipper
Hi Mike, looks like things are coming together for you. Just a reminder, make sure you lap the new valves to the seats and check seat widths...don't want to end up with burnt valves or anything. I'm up in Atlanta again so maybe me and my brother can come up sometime.
To Valve Piston Interference Pictures
