***Straightline Performance LSx Cam Special***
Old Jan 29, 2009 | 02:06 PM
Tuner@Straightline's Avatar
Tuner@Straightline
Default ***Straightline Performance LSx Cam Special***
Time to start spending those Tax Returns!
Comp Cam of choice
Comp 918 Single Springs
New Trick Flow Pushrods
New OEM LS2 Timing Chain
New OEM Front Cover Gasket
New OEM Front Crank Seal
New OEM Water Pump Gaskets
New OEM Crank Bolt
The whole deal comes with a FULL CUSTOM non cookie cutter tune on our state of the art Mustang MD-1100SE Dyno!
As for upgrades you can add whatever you want. Here are a few of the more popular upgrades for bigger cams and horsepower cars!
Dual Springs Add $65.00
Melling Oil Pump Add $125
Double Roller Timing Chain Add $85
The Total Price
(Parts, Tune, and Labor)
$1540 for your F-Body
$1590 for your GTO
$1590 for your TBSS
$1730 for your Y-Body (C5/C6)*
And for your C6Z06
Custom Ground Comp Cam
Comp Cams Push Rods and Hardware
Patriot Performance Extreme Dual Springs
All New GM Gaskets
Mobile 1 Oil and Filter
Installed and Tuned for $1949.99
Plus Tax and Fluids
Old Jan 30, 2009 | 09:34 AM
Tuner@Straightline
Bump^
Old Jan 30, 2009 | 07:51 PM
kmthor00's Avatar
kmthor00
ttt for a great tuner & shop!
Old Feb 3, 2009 | 10:19 AM
Tuner@Straightline
Thanks Ken!
Old Feb 4, 2009 | 10:43 AM
Tuner@Straightline
Bump^
Old Feb 5, 2009 | 09:40 AM
Tuner@Straightline
Bump^
Old Feb 6, 2009 | 09:24 AM
Tuner@Straightline
Bump^
Old Feb 9, 2009 | 09:26 AM
Tuner@Straightline
Bump^
Old Feb 10, 2009 | 10:49 AM
Tuner@Straightline
Bump^
Old Feb 11, 2009 | 12:56 PM
Tuner@Straightline
Bump^
Old Feb 12, 2009 | 09:53 AM
Tuner@Straightline
Ends the 21st!
Old Feb 16, 2009 | 09:39 AM
Tuner@Straightline
Bump^
Old Feb 16, 2009 | 03:25 PM
SpeedFreak81's Avatar
SpeedFreak81
Is there any particular reason why the price for a Vette is almost $200 more than an f body? Doesn't make much sense to me considering I've done them on both cars and the Vette is MUCH easier to work on I think.
Old Feb 16, 2009 | 04:36 PM
Tuner@Straightline
With the Y-body platform, the steering rack in front of the pulley. This usually requires the removal of the front wheels, unbolting of calibers, and sliding the steer rack out of the way. Combined this takes about 45min to an hour on tear down and assembly which is why you see that added cost over the F-body, which does not require these steps.
Old Feb 17, 2009 | 10:19 AM
Tuner@Straightline
Bump^
Old Feb 19, 2009 | 09:57 AM
Tuner@Straightline
Bump^
To ***Straightline Performance LSx Cam Special***
