'05 Engine Won't Crank (turn)
Old Jan 29, 2009 | 05:54 PM
CubanMissile's Avatar
CubanMissile
Default '05 Engine Won't Crank (turn)
Parked the car and everything was fine. Next day, the engine won't crank. Checked fuse, crank/starter relay and they seem fine. Battery is fully charged and there is power to operate windows, etc. Steering column won't lock, though. Any suggestions?
Old Jan 29, 2009 | 10:49 PM
c6 batmobile's Avatar
c6 batmobile
You need to scan it. There are so many electrical variables its going to be a pain to track down.
Old Jan 30, 2009 | 06:17 AM
CubanMissile
Thanks. That was going to be my next step this morning. The Missile has been incredibly reliable, let's see what little surprise we find
Old Jan 30, 2009 | 11:57 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I don't know either. I'm pretty versed on the C-5's but not the C-6's ...but learning. Please tell us what you find. The C-5 has a TDR, Theft Deterrant Relay in the passenger footwell that operates the starter solenoid. You can hear it click when turning the key. If the starter doesn't engage and this relay did, it would have probably been a bad solenoid. I don't have a clue on the C-6 yet....sorry.
Old Jan 30, 2009 | 12:16 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
This type of problem can sometimes be caused by a faulty clutch position switch/sensor.
Check out these two threads:
http://forums.corvetteforum.com/c6-t...ont-start.html (post #39)
http://forums.corvetteforum.com/c6-t...r-working.html
Old Jan 30, 2009 | 03:45 PM
CubanMissile
Thanks. I did jump the clutch switch after reading your post and it did not work. Also tried putting the fob in the slot and it didn't work either. I am also curious as to why the steering won't lock....
Old Jan 30, 2009 | 03:48 PM
CubanMissile
That is exactly what it's doing. The crank solenoid clicks when pressing the Start button and all the electrical circuits come alive but the engine doesn't turn.
Old Jan 30, 2009 | 05:26 PM
dgrant3830's Avatar
dgrant3830
If the solenoid is do its major clicking but the engine isn't turning over, then its easy.. bad battery to solenoid connection or a bad solenoid.
Old Jan 30, 2009 | 07:39 PM
dollarbill's Avatar
dollarbill
St. Jude Donor '06-'07-'08-'09-'10-'11
I have also seen a Window Valet cause this problem. If you have a WV plugged into the Diagnostic Port, then remove it, discxonnect and reconnect the battery and it should start.
Good luck
Old Feb 1, 2009 | 01:36 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
My car did this after tuning...I think it got hosed up. I unhooked the negative battery cable with the door open (to draw current down)...hooked the battery back up and all was fine. I think the car needed a reboot.
Easy to try, hope it works.
Old Feb 1, 2009 | 02:46 PM
Johnny vette's Avatar
Johnny vette
Try Charging the Battery. I Bet that Works ....
To '05 Engine Won't Crank (turn)
