Which coilover set up uses the stock leaf?
Old Feb 3, 2009 | 09:27 PM
Boomer111's Avatar
Boomer111
Default Which coilover set up uses the stock leaf?
I came across it and can't find it again.
Old Feb 3, 2009 | 09:31 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
None? Wouldn't a coilover using a leafspring not be a coilover?
Old Feb 3, 2009 | 09:43 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Eibach/Callaway coilovers use the stock leafs. The springs they use on the coilovers are in addition to the leaf springs.
San
Old Feb 3, 2009 | 09:51 PM
Boomer111's Avatar
Boomer111
Thanks, it was the Eibach system I was thinking of. Ya not really true coilover but it is height adjustable.
Old Feb 3, 2009 | 09:53 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
It has a coil, helper spring and strut, so I would say it is a true coilover. It just doesn't use as strong a spring as a coilover without a leaf spring would.
San
Old Feb 3, 2009 | 10:33 PM
455HOGT37's Avatar
455HOGT37
San
Ummm...
What exactly is the point of springs in addition to the stock spring (helper springs)? It's not like anyone is going to be hauling a load of gravel in the back...
Old Feb 3, 2009 | 10:36 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Yeah, what's the point of hauling around the weight of three springs instead of two (coil) springs?
Old Feb 3, 2009 | 10:51 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
To firm up the ride? The coilsprings add to the total effective spring rate.
San
Old Feb 4, 2009 | 09:32 AM
455HOGT37's Avatar
455HOGT37
OK, I guess some people need a higher spring rate... Isn't there a firmer leaf available though? Seems like that would be more cost effective and would provide less unsprung weight than the leaf/coilover setup. Also, if you're going to go to the expense and trouble of putting "sorta" coilovers on the car, why not do it right and ditch the stock leaf? To do both seems like kind of a half assed fix, like adding air shocks to a Chevelle to clear fat tires.
To Which coilover set up uses the stock leaf?
