Help. Check Gas Cap after FAST install
Old Mar 3, 2009 | 08:34 AM
  #61
quick Ag's Avatar
quick Ag
Originally Posted by Joe_G
Guy I haven't had a chance to pull my throttle body off to look at this, but when the car is idling, that port definitely pulls vacuum so the port is at least somewhat open. If I stick a drill bit in the port, it stops about 3" in however.
Is that port supposed to be completely open clean through to the plenum? Are the ones you are seeing blocked completely blocked are or they partially blocked? I can take the throttle body off again and drill it out but thought I'd ask first.
Hey JOE G,
Trust me on this one, even partially blocked you'll still trigger a code. That port needs to be open clean through into the plenum, as Spin indicated, just remove your throttle body and drill out the port so that you can see that you are all the way through into the plenum. Once you do that I think you should be just fine.
Good Luck
Old Mar 3, 2009 | 09:05 AM
  #62
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Originally Posted by quick Ag
Hey JOE G,
Good Luck
Cool. I never would have guessed this would be a problem as if its pulling vacuum I would figure it's fine.
Thanks for the tip, I'll knock it out tonight hopefully!
Old Mar 3, 2009 | 10:13 PM
  #63
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
My FAST 92 had the evap hole completely plugged. A standard 5/32" drill bit can be chucked in a drill to leave 2-3/4" available. When I drilled all the way thru, with the chuck just kissing the plastic, about 1/8" of drill bit was sticking through on the inside. If Joe_G is really getting blockage at 3", it is because something is sittin' in the middle of his manifold !!
Mine is finally going back together tomorrow night, so this information was QUITE TIMELY !! Thanx, Corvette Forum.
Old Mar 3, 2009 | 11:41 PM
  #64
bent's Avatar
bent
WOW.
Even with the bickering/man drama, the forum pulls off another amazing find/fix. WHAT A TEAM!!!!!!!!
Old Mar 4, 2009 | 09:24 AM
  #65
AeroJim's Avatar
AeroJim
Would you happen to have any pics, of the location of this port? I have the same thing happening after the fast install.
Hey JOE G,
Good Luck
Old Mar 4, 2009 | 09:35 AM
  #66
Buddy A's Avatar
Buddy A
It's the port on the front side of the intake, next to the throttle body, and on the drivers side. The hard black plastic purge line attaches to it when installed. I'm sure someone has a picture somewhere.
Old Mar 5, 2009 | 12:50 AM
  #67
SpinMonster's Avatar
SpinMonster
A 1/8 inch bit wont get through even on manifolds that arent plugged. The hole is smaller than 1/8 inch.
I doubt your's is plugged.
  #68
SpinMonster
Did you get your manifold back today?
Old Mar 5, 2009 | 11:51 AM
  #69
Buddy A's Avatar
Buddy A
Not yet. Fed Ex says tomorrow it will be delivered.
Old Mar 5, 2009 | 12:09 PM
  #70
siffert's Avatar
siffert
I wonder if this is a possible issue on Fast 90's too.
Old Mar 5, 2009 | 12:17 PM
  #71
dennis50nj's Avatar
dennis50nj
pm sent your full
Old Mar 5, 2009 | 06:08 PM
  #72
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
Just got back from AeroJims, his FAST 92 also has the clogged port problem.
Old Mar 5, 2009 | 06:21 PM
  #73
Buddy A's Avatar
Buddy A
I e-mailed FAST and they stated they had no clue there was a problem. Seems to be pretty wide spread. Or we on the forum all have bad luck........LOL
Old Mar 5, 2009 | 06:28 PM
  #74
pmj341's Avatar
pmj341
I wonder how far back this goes??
Old Mar 5, 2009 | 09:23 PM
  #75
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I bought mine a week before SEMA so late October...I must have the problem as I get a check gas cap every time I drive now (I reset it each time) and my gas cap is perfect. One time had a problem with my cap not "catching" but it's been working perfectly now for a while.
I'll drill it out this weekend and report back.
Old Mar 6, 2009 | 09:41 AM
  #76
AeroJim's Avatar
AeroJim
Joe, Please let me know if you have any sucess when you drill it out and what method you used.. I assume you're going to do it while the manifold is still on. Craig (Craigster05) and I attempted to fix mine yesterday, but ran into clearence issues with the alternator bracket and drill. We even went to sears and bought a mini right angle drill but that was to big as well. I'm going to look for some smaller type of righ angle drill today but I'm not optimistic.. I kind of think the mainfold may have to come off to get it done.. I hope you have better luck.
Old Mar 6, 2009 | 09:44 AM
  #77
Joe_G's Avatar
Joe_G
St. Jude Donor '08
That is my fear as well....my wife has a cordless right angle drill that's small I hope it works...I don't feel like taking that manifold off again!
To Help. Check Gas Cap after FAST install
Old Mar 6, 2009 | 09:45 AM
  #78
Buddy A's Avatar
Buddy A
Try a sharp drill bit using just your fingers. Would probably work but take a while. I'd presume it would be better than removing the manifold. Worth a shot. Basically it's plastic, so the sharp bit should work.
Old Mar 6, 2009 | 09:52 AM
  #79
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Hmm.. I've got some drill bits that have an adaptor fused to them that fits in a standard cordless drill chuck, I could use a ratchet and socket to turn it, but that would be pretty slow work! Gotta balance that out with just taking the manifold off which is about 15 minutes.
Old Mar 6, 2009 | 10:00 AM
  #80
pmj341's Avatar
pmj341
Joe if you're coming to Sebring I have an aircraft 90 degree drill, it will get the job done.
Phil
