Crunching on 1-2 upshift (MN6)
Old Feb 12, 2009 | 12:46 PM
i_york's Avatar
i_york
Default Crunching on 1-2 upshift (MN6)
I've noticed that, when I'm gunning it in 1st gear and I quickly upshift to 2nd at high revs, I get a slight crunch on the 1-2 shift. During normal driving, this never happens. I'm thinking either I have a worn synchro (car only done 25k miles) or/and I need new trans oil. Or, maybe I'm just 'beating' the synchros?
Anyone had 1st-hand experience of this issue? Car is a 2005 Z51.
Thanks,
Ian.
Old Feb 12, 2009 | 01:05 PM
autoxnut's Avatar
autoxnut
Ian,
My 2005 Z51 transmission failed at about 64,000 miles. I am currently in arbitration with Easy Care, an extended warrranty company, concerning the coverage of the repairs. My replacement transmission exhibits a notchiness when going from 1st to 2nd, particularly when cold. It is not related to RPM. I believe this is indicative of weak synchro design which was changed for the 2008 model year which uses the T6060 transmission. The original transmission also exhibited similar issues. If I had it to do over again, I would change the transmission fluid and look very carefully for any sign of metal paticles and seek repair under warranty if any are found.
Old Feb 12, 2009 | 01:10 PM
i_york's Avatar
i_york
Originally Posted by autoxnut
Ian,
Yea, I've got the notchiness when cold, too. It's ALMOST as bad as the Ferrari F355 I had (although with that car, you could probably bend the shifter trying to get it into 2nd when stone cold!). The high RPM shifting, however, is a definite crunch/grind rather than notchiness (which eases-up once the gear oil is warm). Think I'll change the trans oil as a first step.
Anyone else?
Old Feb 12, 2009 | 02:16 PM
torquetube's Avatar
torquetube
All of the above. Too much of #3 with a dash of #2 has led to #1.
To Crunching on 1-2 upshift (MN6)
