Question about "Tail Taming"?
Old Feb 13, 2009 | 02:14 PM
miami08VETTE's Avatar
miami08VETTE
Default Question about "Tail Taming"?
I have upgraded sways to Hotchkis sport sways. I am running them with the rear set to the middle hole which is 45% stiffer than stock. The tail is a little loose and wild under powered turns and curves. I want to confirm that I need to tune it to the outer hole which is the lightest setting at only 15% stiffer than stock to tame the tail a bit.
FYI I also run the Koni FSD shocks now.
Old Feb 13, 2009 | 03:12 PM
Dirk Miller's Avatar
Dirk Miller
Default Dirk Miller
I presume you have an '08 C6. What suspension did this come with?
Old Feb 13, 2009 | 03:31 PM
miami08VETTE
Z51 and yes it's an 08 coupe.
Old Feb 13, 2009 | 04:45 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
The further out you get the end link the softer the bar will become. The softer the bar the more traction.
Randy
Old Feb 13, 2009 | 05:41 PM
miami08VETTE
Randy
Thanks Randy. I just wanted to be sure. I got the basics at a high level but once it comes to tweaking I want to make sure I have some input and confirmation.
I will move the bar/end link to the outer position tomorrow and see if the tail settles down.
To Question about "Tail Taming"?
