Smoke!
Old Feb 14, 2009 | 12:09 AM
bus#82's Avatar
bus#82
Default Smoke!
I have a 05/c6 stock everything with 48000 miles, i take it out about 4 to 5 times a mth,the last few times upon start-up it smokes bad for about a minute or two and then is fine the rest of the day, any thoughts on why? and what should i do?
the engine is a 400, the smoke is white or gray, more white
bus#82
Old Feb 14, 2009 | 01:13 AM
c6 batmobile's Avatar
c6 batmobile
sounds like your burning a little oil. My beater pick up does the same thing untill it gets warmed up.
Old Feb 14, 2009 | 09:00 AM
ntrimm's Avatar
ntrimm
bus#82
This may sound funny, but I could also be as simple as steam. A little condensation burning off. Does it smell like burning? if not then it is definitely steam.
Old Feb 14, 2009 | 10:36 AM
bus#82's Avatar
bus#82
It dosen't smell like anything, thanks for the input.
Old Feb 14, 2009 | 11:20 AM
saplumr's Avatar
saplumr
I had 2 fuel injectors stick and it billowed white smoke.
Old Feb 14, 2009 | 02:12 PM
calemasters's Avatar
calemasters
I agree. If not steam, it could be valve guide seals leaking a little oil in to the combustion chamber(s).
Also, are you loosing any coolant?
Old Feb 14, 2009 | 02:24 PM
ipmtim's Avatar
ipmtim
Cruise-In VIII Veteran
St. Jude Donor '06
Valve guide seals was my first thought, but that is usually one blue puff at start up.
One of the byproducts of a internal combustion engine is moisture. That is probably what it is.
Tim
Old Feb 14, 2009 | 07:39 PM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
Tim
valve guide seals
Old Feb 14, 2009 | 09:29 PM
Spying Beast's Avatar
Spying Beast
Originally Posted by pmj341
valve guide seals
x4
My old Iroc Z did that to me way back in the day....
Old Feb 15, 2009 | 07:56 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
valve guide seals
Old Feb 16, 2009 | 03:33 AM
MEATHEAD's Avatar
MEATHEAD
pull the 1# and 8# plug if there is oil 0r wet plug its the head.
To Smoke!
