Trans fluid
Old Feb 14, 2009 | 08:48 AM
2kvert's Avatar
2kvert
Default Trans fluid
I need to add some transmission fluid to my manual tranny. Besides the obvious "drain and replace with better fluid" option, what can I buy off the shelf at the local parts store that is the same as what's in there from the factory?
Old Feb 14, 2009 | 11:15 AM
ipmtim's Avatar
ipmtim
Cruise-In VIII Veteran
St. Jude Donor '06
The manual calls for Dexron III ATF.
I just drained and refilled with Red Line D4 last night.
For those who have not done this, I have 32K miles and the fluid looked like used motor oil. I should have done this sooner.
Tim
Old Feb 14, 2009 | 11:18 AM
ipmtim's Avatar
ipmtim
St. Jude Donor '06
I just noticed you have a C5. The info I posted is for a C6, don't know if it applies to your car. Check your manual.
Old Feb 14, 2009 | 01:34 PM
2kvert's Avatar
2kvert
No that was my C5Z. I actually have a C6 convertible and a C6 coupe and the convertible lost some fluid during a radiator swap and is giving a whine going through the gears so I need to add some fluid. Thanks for the info.
Old Feb 14, 2009 | 02:03 PM
calemasters's Avatar
calemasters
You can buy Mobil 1 Synthetic ATF at PEP Boys and other stores. It meets the Dexron III, spec "H" requirement.
Old Feb 15, 2009 | 12:04 PM
cuss's Avatar
cuss
Tim
The factory owners manual states the c6 Manaul transmission fluid is lifetime - no replacement schedule??? Why would GM suggest this? How often have other replaced and what replaced with?
Old Feb 15, 2009 | 02:04 PM
tdelena's Avatar
tdelena
St. Jude Donor '12, '14-'15, '17, '20
Tim
and did the same. Changed it at 34k and it looked like crap(dark brown) with lots of metallic. Should have done it much earlier. I also used the Redline D4 ATF and the is a slight improvement in shift action although mine had always been pretty good.
Old Feb 15, 2009 | 10:41 PM
ipmtim's Avatar
ipmtim
St. Jude Donor '06
tdelena,
Same here. I think I'll do it again in about 20K for good measure.
Tim
Old Feb 15, 2009 | 10:46 PM
ipmtim's Avatar
ipmtim
St. Jude Donor '06
No idea, I'll read mine closer. But I can tell you it looked like burnt trans oil from an automatic, and I prefer clean fluids in my car.
I've seen 4 or 5 posts on this, so I went for it.
Tim
Old Feb 15, 2009 | 11:00 PM
cuss's Avatar
cuss
Makes sense to me. What harm could it do if you are using a compatible fluid. So far, looks like the Redline D4 is the most popular. I have only 10k on my new C6. I think I'll change it out now as I am sure there is some "break in" with the tranny. Why have all those metallic particles floating around in there.
Any feedback on that Z-max tranny additive I see on all the car shows?
To Trans fluid
