LS2 Engine Squeal
Old Feb 25, 2009 | 11:40 AM
Naeblis's Avatar
Naeblis
Default LS2 Engine Squeal
2005 60k miles
Last night my engine started to make a loud noise while I was driving down the highway. When i got home I was able confirm it was the belt. today it went away. So i have a couple of questions
1) what is the normal operating temp of the engine
2) what is the normal life span of the Belt
3) do the Non-gmpp, extended warranties that you get form the dealer cover belts, I don't think so. But I think it might have killed the water pump. Since the engine is operating at less than 200 degrees now.
Old Feb 25, 2009 | 12:24 PM
knkali's Avatar
knkali
a bad water pump would caudr INCREASE in temps.
normal op temp is around 200-210
Old Feb 25, 2009 | 12:39 PM
Naeblis's Avatar
Naeblis
Ok thank you for that.
Thom
Old Feb 25, 2009 | 12:49 PM
dbradley's Avatar
dbradley
Don't know your mechanical skills so, either check or have checked. Remove belt and check ALL rotating assemblies for roughness or "loose" pulleys. While off look the belt over for cracks. At 60k miles it is possible that you need a belt, maybe idlers....
Old Feb 25, 2009 | 01:39 PM
c6 batmobile's Avatar
c6 batmobile
Could be a tensioner or the pulley that routes the belt down.
Old Feb 25, 2009 | 06:30 PM
85Z514+3's Avatar
85Z514+3
You may want to confirm that you do not have a problem with your harmonic balancer that affected some 2005's. There is a TSB for this problem and plenty of posts on the forum.
Old Feb 26, 2009 | 06:09 PM
jam313's Avatar
jam313
This.
I had the same type of noise, and when I got home, popped the hood, grabbed the crank pulley bolt (harmonic balancer) and it was less than hand tight.
Old Feb 26, 2009 | 09:58 PM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
Scary Stuff
Old Feb 26, 2009 | 10:28 PM
welcome2try's Avatar
welcome2try
From: Objects in your mirror are losing , Long Island, NY
St. Jude Donor '08
Originally Posted by pmj341
Scary Stuff
Indeed, catastrophie of epic proportions.
To LS2 Engine Squeal
