engine troubles, need help!!
Old Mar 2, 2009 | 09:54 PM
22'vette's Avatar
22'vette
Default engine troubles, need help!!
i have a 07 C6 manual transmition, with a 112 magnacharger, american racing long tube headers, nitrous oxide, straight back pipes without mufflers... my problem is that as i start to accelerate, the engine seems to stall or cut out, through the gears...and every so often, as i am driving i will turn off the car, and then restart it and the car will seem fine...can someone please tell me what they think is going on, or if this has happend to you....any input will be appreciated...
Old Mar 3, 2009 | 01:36 AM
thomas walters's Avatar
thomas walters
Any codes being thrown?
Old Mar 3, 2009 | 10:37 AM
vettl83's Avatar
vettl83
You might want to move this post to the C6 FI section of the forum.
Old Mar 3, 2009 | 10:50 AM
seevi's Avatar
seevi
Did you change your fuel injectors?
Old Mar 3, 2009 | 12:41 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Do you have an engine monitoring software such as EFILive where you can actually look at the PIDs and see what it's doing when the "fail" occurs? Otherwise you're shooting in the dark.
Elmer
Old Mar 4, 2009 | 11:09 AM
seevi's Avatar
seevi
there are a couple of trial scanning packages you can get that will give you the PID's. All you need is the OBDII hardware, and you can get that on eBay very inexpensively.
Elmer
To engine troubles, need help!!
