DIY Gear Change
Old Mar 3, 2009 | 04:59 PM
Ragtop 99's Avatar
Ragtop 99
Default DIY Gear Change
I did it years ago on an F-body and it wasn't that hard. Has anyone changed their ring and pinion gears on the C6? I'm more interested in that rather than swapping pumpkins since I know my unit's history and relatively low mileage.
If you did it, were there any special tools needed? Any reference material that I could look at?
Old Mar 3, 2009 | 05:07 PM
c6 batmobile's Avatar
c6 batmobile
Ive heard its kinda rough on these cars. I was considering doing mine and was talked out of it by someone who had done it.
Old Mar 4, 2009 | 09:17 AM
Ragtop 99's Avatar
Ragtop 99
nobody has done it??
Old Mar 4, 2009 | 12:11 PM
lgm118icbm's Avatar
lgm118icbm
I just swapped the whole differential which wasn't that bad at all.
I don't have much input about cracking into the diff though.
Old Mar 8, 2009 | 08:17 PM
DaBullish1's Avatar
DaBullish1
How do you know if the gear oil is high enough? I had an RPM differential and T56 put in my car using an out of town shop. The came home Saturday morning. Today I was getting ready to detail the car and found gear oil on the back bumper. I put the car up on my four post lift and found gear oil puddled on top of the diff near the overflow. When I pulled the plug I could not feel the oil unless I reached way in. The surfaces were very oily, I just could not feel the pool until I stuck my whole pinky in. Does this seem right to you?
To DIY Gear Change
