courtesy lights problem
Old Mar 6, 2009 | 02:42 PM
gmrx's Avatar
gmrx
Default courtesy lights problem
when i washed the car clean inside i noticed that interior lights are not turning off. i cannot turn off reading lamps in the mirror by pressing the button. side lamps on the leg compartments don't have switch. of course doors were closed. first i thought that maybe some water came to the locks. although it seems rather impossible i took away the fuse and wait couple of days, but after putting fuse to the place lights are still on all the time.
do somebody has that problem?
as my waranty passed maybe you guys know what to do?
(i can drive without interior lights but there is no solution)
Old Mar 6, 2009 | 02:51 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Check the button for the dimmer switch. You might have pushed it in by accident. It controls the courtesy lights AND the dash dimmer. Push it and see if the lights don't start behaving.
Elmer
oneblackvette's Avatar
oneblackvette
Hey the switch that adjusts the dash lamps, if you push it turns all the interior lamps on. Try giving it a push. Dad does this all the time when dusting the interior.
Old Mar 6, 2009 | 03:03 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Check the following:
  • Press the Reading Lamp Buttons under the rear view mirror to turn them on/off.
  • Push the Instrument Panel Brightness **** in to turn on/off the interior lights.
Old Mar 6, 2009 | 06:28 PM
c6 batmobile's Avatar
c6 batmobile
Im having the same problem with my 05. I tried to push the button but nada. Dont know what Im going to do next. Hopefully someone has some usefull info.
Old Mar 6, 2009 | 09:27 PM
BluV's Avatar
BluV
St. Jude Donor '09-'10
And - after you push the dimmer switch in, don't forget you will need to wait several seconds for the "dim down" to kick in. I don't remember how long it is - but at least 15 seconds for the dimming to start.
They won't just go off immediately....
Old Mar 7, 2009 | 05:48 PM
gmrx's Avatar
gmrx
thanks guys for your help. i didn't know that the switch that adjusts the dash lamps also turning on and off courtesy lamps. although i rotated it left and right i dont push it or wait several seconds to work. i thought that sth is wrong because i cannot turning off lights on mirror by pusshing the button.
long story making short: i act like blondie girl, shame on me.
that forum is great!!!!!!!!!!!!!!!
thanks a lot.
To courtesy lights problem
