Maf screen removal
Old Mar 6, 2009 | 04:16 PM
gunnerrun's Avatar
gunnerrun
Default Maf screen removal
Will it cause any difficulties tuning or effect performance in an 05 6MN?
Old Mar 6, 2009 | 04:23 PM
HawaiiC6's Avatar
HawaiiC6
I removed mine when I installed my ported and polished throttle body, no problems since the removal which is over 10K miles ago. Unknown if it increased performance, however to me it was a restriction in the intake system.
Old Mar 6, 2009 | 06:15 PM
gunnerrun's Avatar
gunnerrun
Makes sense. Hoping to hear from some tuners.
Old Mar 6, 2009 | 06:20 PM
c6 batmobile's Avatar
c6 batmobile
The reason its there is to catch large material that might accidentally slip past the air filter. I know someone who removed theirs and the air filter actually failed and was sucked into the intake maifold because it wasnt there to stop it. Pretty rare but why take the chance you wont really net any huge gains from it.
Old Mar 6, 2009 | 06:33 PM
REVAK's Avatar
REVAK
Default maf screen
Z06's have no screen from the factory. I have removed the maf screens on all of my LS1, LS2's ,[ 3 ] , started doing that over 10 years ago. No problems , I do recommend tuning afterwards, not necessary but beneficial to do so . LTFT's will be affected approx. 10%.
Old Mar 6, 2009 | 06:43 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
I left mine in after installing a ported throttlebody. I just felt that it was there as a backup to prevent ingesting foreign bodies and believed that was a good thing.
Old Mar 6, 2009 | 06:54 PM
PAUZAO's Avatar
PAUZAO
I was told that the function is mostly to reduce turbulent air, and smoot it out. My LS3 did not have that screen.
Old Mar 6, 2009 | 07:12 PM
calemasters's Avatar
calemasters
The screen slightly increases the accuracy of the MAF.
Old Mar 6, 2009 | 07:15 PM
old motorhead's Avatar
old motorhead
Unless you're running some real serious HP, there's no reason to do it. I'm not sure the stock MAF is a restriction under 600 engine hp. I went speed density on a supercharged LQ4 that made 600+hp. Removing the MAF completely yielded a HP increase of plus or minus "0". Driveablitly did increase though.
Old Mar 6, 2009 | 08:08 PM
TTZ06VETTE's Avatar
TTZ06VETTE
That's the purpose of it. People with early model OBDI cars pay to have these installed to reduce the turbulence hitting the MAF sensor. Becomes especially important with Forced induction.
Old Mar 7, 2009 | 03:45 AM
SpinMonster's Avatar
SpinMonster
FI cars benefit from the 100mm lingenfelter unit to the tune of 20rwhp. I got rid of it on my car at 700+rwhp....paxton S/C.
A stroker car (440CI) making 510rwhp swapped to a 100mm unit and gained 30rwhp.
On LS3's and LS7's there is no screen and it isnt needed.
The C5 Z06 used the screen on all models except the 2002+ Z06 because its a flow disruption and the car benefits from deleting it. I had a max-effort 348 forged motor in my C5 with nitrous and I deleted it picking up 9rwhp with better driveability.
It is not for straightening out air. The flagship 2002+ Z06 got rid of it for power gains thus GM knew it was not helping performance.
I wish this rumor would die already or please post the source of your info. I dont think you can because GM never said it.
Old Mar 7, 2009 | 03:47 AM
SpinMonster
Please post the source; who 'told you'?
Old Mar 7, 2009 | 03:52 AM
SpinMonster
MAF facts.
At 400rwhp dont touch it. It isnt going to do anything until you hit a power level where its warranted.
At 500rwhp, the car will benefit from a 299 dollar 100mm Lingenfelter MAF 12-15rwhp and a tune is needed for it.
At 600rwhp (forced induction included) the stock MAF is maxxed out and will benefit from it being swapped out for a bigger unit or running in speed density.
At 700rwhp, no MAF will meter that high on some year cars no matter what size it is.
Keep in mind that N2O is its own air supply and wont affect MAF levels if its a wet shot.
Old Mar 7, 2009 | 04:19 AM
Wayne88's Avatar
Wayne88
I was told that the function is mostly to reduce turbulent air, and smooth it out. My LS3 did not have that screen.
I've read that several times in the C4 forum.
I can't say if it's true or not, just that I read it several times.
Old Mar 7, 2009 | 05:05 AM
SpinMonster
Forums are repeated rumors. A tech article with verified testing is the only true source of info.
Now people can say they read in the C6 tech section that the screen is costing power, and GM agrees by deleting it on the faster cars. It wouldnt make sense if it helps performance for GM to take the screen off the 2002 Z06 and leave it on the 2002 base C5 would it? Well thats exactly what they did in 2002....a fact.
Old Mar 7, 2009 | 12:42 PM
TTZ06VETTE's Avatar
TTZ06VETTE
If the screen isn't there from the factory and GM engineered it that way, I agree you don't need it. I have the Lingenfelter MAF on my car. The MAF is there to facilitate tuning and help reduce the sensitivity to the turbulence of air passing over the sensor(design). I still have spark drop off at low RPM cruising speeds due to the design of my intercooler hood and the turbulence of the air passing through the MAF at low speeds. High speeds with higher airflow are fine as this is where the Lingenfelter MAF outperforms the stock unit. I probably would benefit from a screen on my MAF...or a redesign of my intercooler hood. Either way I would need to retune.
Prior to this I owned a turbocharged BMW M3 OBD I that experienced the same low speed driveability issues due to the remote location of the air intake. After many many months of attempting to tune the problem out, I ended up adapting a screen to the front of the MAF to straighten out the airflow and it fixed the problem.
My experience
Old Mar 7, 2009 | 01:59 PM
gunnerrun's Avatar
gunnerrun
Default Sources and Experience
The responses with sources or personal experience are really helpful. Thanks to all that have replied. I believe I'll keep a screen in place.
To Maf screen removal
Old Mar 7, 2009 | 03:24 PM
07MontRedcp's Avatar
07MontRedcp
Here is an interesting tech article. Granted it isn't a maf screen per say, but is does consider the effects of a screen across an air flow.
http://ateam.lbl.gov/PUBS/cec/Append..._Fume_Hood.pdf
BJK
Old Mar 7, 2009 | 05:24 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
BJK
Thanks for sharing this article; very interesting indeed.
Old Mar 7, 2009 | 07:08 PM
timd38's Avatar
timd38
This has been debated for years....
