Maf screen removal
LOL so all 2002-2004 Z06's have poor performance with FI
How on earth do they ever run right with no screen.
Why did GM take it out for the faster car?
Is that why ECS/Doug ditches the MAF?
I have FI and ran with 100mm, stock, and descreened MAF's and none had issues with turbulance.......
They all ran fine until they were maxxed out; perfect driveability. The only issue I ever saw was a maxxed out unit tripping the HF fail test.....with all of them.
If even one car runs right without the screen on FI, then its not an issue to descreen. Mine runs fine without it.
IT is best to leave it unless you are making changes that change air flow, such as force induction or engine displacement changes....
However....since it affects conditions at essentially idle...removing it will not affect performance at higer than idle rpms....IT is a game to reuce emissions, the fleet GM makes is looked at as a whole with regard to emissions, at idle cars are quite dirty, the screen improves this, but the results are only visible when all cars are looked at together, not inividually....
In the end words like "always" or "never" just do not apply in all cases since each case is specific to the circumstance.
A stroker car (440CI) making 510rwhp swapped to a 100mm unit and gained 30rwhp.
On LS3's and LS7's there is no screen and it isnt needed.
The C5 Z06 used the screen on all models except the 2002+ Z06 because its a flow disruption and the car benefits from deleting it. I had a max-effort 348 forged motor in my C5 with nitrous and I deleted it picking up 9rwhp with better driveability.
It is not for straightening out air. The flagship 2002+ Z06 got rid of it for power gains thus GM knew it was not helping performance.
I wish this rumor would die already or please post the source of your info. I dont think you can because GM never said it.
Heresay has just as much value here as it does in court.
FI cars dont run it.
C5 Z06 deleted it at the factory and you may want to take a look at the air cleaner assembly before you quote that GM uses it whern the assembly needs it. No screen and its exactly the same as the base C5 with a screen. This car can pass emissions even with a cam 20 degrees more intake duration than the stock cam so its not even close to needing a screen for that reason. Saying the LS engine is dirty at idel is really misinformed. Its actually one of the cleanest running engines around and my C5 w/forged 348 with a 224/230 cam and ported heads with no screen on the MAF passed emissions for years in NY when they had the sniffer.
I ran my C5's and C6's without them and just about every car I tuned and they span the universe for power levels and thereofre air flow levels....stock to 800hp. I have yet to see a car lose power from it so please produce even one car that did.....any power level.
Post them here too so we can see the lower dyno numbers with the lack of laminar air flow straightening science.
The only debate over time has been the types of people tackling fluid mechanics problems. Those that understand, those that do not understand, and those that desire to learn.
The Reynolds number does not care about dynos, tracks, streets or garages. There really is nothing magical about it as you say, its beauty is in its simplicity. It does not matter the car, F1 or Tata....It is a function of velocity, dynamic viscosity, diameter (in this case) and density.
The point where we are talking here is at the MAF, so the air filter has is really just a minor loss in the flow equation. We are also not talking about laminar flows, since the intake does not flow in that regime under operating conditions.
Since fluid flow (air) is conserved in our engine system, to change the need to have the screen or not, you will need to change something in the Reynolds equation. Holding the other variables at STP, to increase HP in our engines, flow of air is increased either by increase in displacement or pushing more air into the engine. Beautiful, isn't it?
Can you remove the screen? Sure....Is the MAF sensing element calibrated to have the screen there? Sure is. What will removing the screen affect? A slight increase in the pressure (decrease in vacuum) of the air reaching the cylinders by removal of the screen as a minor loss; and the calibration of the MAF sensing unit since it was calibrated to have the screen there.
As for the engine being dirty at idle, all engines are dirtiest at idle conditions, that is common knowledge and our vette engines are no different. Anything GM does to make this condition better, when applied across the fleet, makes their environmental emissions, as a whole, better.
I did not purchase this intake, it came on the car. However, this is the 2nd Vararam product that I've had on a vehicle of mine and the quality of both has been trash. Thanks to screened MAF's and their ability to pick up the slack where Vararam left off
Damn, that is worse than mine! My Vararam had sand in it when I took it off though
For what its worth; both tuners I consulted with before supercharging my car recommended me to NOT remove the screen; their reasoning was that the gains are negligible and MAF accuracy is reduced without the screen in place.
Not being a dick, but I can just see this thread getting de-railed into a my CIA is better than yours e-fight.
That's the purpose of it. People with early model OBDI cars pay to have these installed to reduce the turbulence hitting the MAF sensor. Becomes especially important with Forced induction.
