DIC: Service Charging System??
Old Mar 9, 2009 | 01:30 PM
sallen619's Avatar
sallen619
happened to me...had to get a new alternator...the terminal had corroded.
Old Mar 11, 2009 | 09:06 AM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Service charging system.....
Originally Posted by LS2-Zomb!e
What is that?
Pops up every 2 days or so! anyone know what is it? do I need to check anything?
Thanks a lot!
Service charging system.....happens when you kiss Mr.HIGHRPM.
Basically, a really mean OVERREV will cause the alternator to fail.
Some of the time it can happen that the alternator outright fails to charge and then you're replacing it.
Most of the time, if it continues to charge, you can simply turn off the "L-terminal" code that sets and the message on the DIC goes away...I've done this with cars 2 and 3 years ago and they're still fine to this day.
That's all it is....Just make sure it's charging.
Chuck CoW
Old Mar 11, 2009 | 09:17 AM
FedAppLawCtr's Avatar
FedAppLawCtr
Default Dic
Happened to me with a new 07 Z06 the first week I had it. Replace the alternator. Dealer advised the contacts in the alternator were bad when applying any considerable amount of rpm's.
Old Mar 12, 2009 | 04:22 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Chuck CoW
Thanks a lot Chuck, It's gone now by itself. Is it normal?
Old Mar 12, 2009 | 11:31 AM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
I had the san=me problem just a short time ago and found it was caused by a connection from the to the Battery.
Old Mar 12, 2009 | 05:18 PM
Smitter's Avatar
Smitter
Originally Posted by RichieRichZ06
We have been replacing more alternators on C6's lately then ever before for this reason. Also, check the terminals on the alt connector. I have seen some of them coming apart lately.
This is the kind of thing warranty is good for.
I had the same message due to low battery but a couple weeks later I took it in for service and ended up with a new alternator. Originally I was told they had to check the computer and that some cars have had a problem if they had hit the rev limiter.
Old Mar 12, 2009 | 06:41 PM
TANGLVR's Avatar
TANGLVR
This happens to be a problem for a lot of folks, especially those with underdrive pulleys. Many people have been hosed into replacing the alternator when it wasn't necessary. Here area couple options:
1) edit the software settings to not trip the alarm at the lower values...BUT we drive a performance auto and for those of us with tuned cars it is NOT a good idea to do this--hell even if you're car is stock don't do this. Fuel Pumps, injector cycles, and various other aspects of the car that are voltage controlled need the right voltage to avoid lean conditions, detonation, engine damage, etc. I advise AGAINST this. Sorry, just my .02
2) Lose the underdrive pulley and post it in the For Sale section. It's not giving you that much HP. Opt for an electric water pump to make up the difference.
3) Edit the software to have the error code for this completely removed...not my recommended solution.
4) Do what I did through my tuner...Cartek...swap out the alternator pulley to spin it into the right range to give the appropriate voltage so everything is happy!!! Cost about $100 bucks!!!
Just my .02, not an expert but I've live this one.
Old Mar 12, 2009 | 06:56 PM
DSOMC6's Avatar
DSOMC6
Option 5) Ignore it since it only happens infrequently.
