what exactly is modded on these to make them fit properly on the vette?
The back of the FAST touches the firewall so you either have to cut into the firewall or cut the back of the manifold for it to fit without touching.
The MAP sensor is on the back of the LS1 manifolds and thus it needs to be moved to the front of the FAST to where the LS2 has it or extend the wire and make an even bigger cut into the firwall to fit it.
Last up is the fuel rail mounting that simply uses oversized washers to overlap the the hold down points.
Porting up to doubles the power gains.
Its worth the trouble because the gains can be as much as headers.
