Service active handling system while Autocrossing
--Dan
If you got a "Service Tire Monitor" message you wouldn't be able to go into Comp mode or turn off AH completely.
I don't think your AH message has anything at all to do with no sensors. The AH system uses yaw rate sensors and accelerometers to sense the turning rate of the car, and it can tell if the tail-end is letting loose and will put on individual brakes to try to keep the car from swapping ends or spinning out. I believe the AH talks to the ABS through the EBCM.
If you were running in AH full on or in Comp mode you may see a message "Handling Active", meaning the AH is doing its thing. Are you sure that wasn't the message you saw? That would be perfectly normal to see that any time you invoke AH. If you have AH all the way off you won't get that message because, well, the AH system is off.
So....I don't think the message has to do with no sensors.
BTW, if you have sensors in your Autox tires, why don't you just "marry" them? You can get a tool for $114 and it takes about 60 seconds to register the sensors every time you swap wheels/tires/sensors.
Bob
If the OD of the tires is much different than stock sizes, it may be confusing the AH system.
You should be able to use comp mode autocrossing without issue. My bet is that either having the sensors not married, or your tires diameter difference from front to rear is too big or small compared to the stock tires, confusing the system.
FYI I use 275/35/18 Front and 305/35/18 track tires and can use whatever mode I want without any error messages but,I marry the sensors each time I change from street to track wheels.
http://store.katechengines.com/share...unt2=320243477
It sells for $140 and I don't know what shipping is. They had a 20% off sale going on until the end of Feb - maybe if you call and tell them you're a forum member they'll honor that price.
Check your PMs and I'll send you a link to another one sold by a source that is not a forum vendor.
Bob
