I don't mean to rain on your parade, but I take safety issues very seriously. If you want an honest analysis: Your tube looks too small, you have no cross bracing, you are missing welds and some of the bends look "iffy."
That cage would be fine "just for looks" but it probably didn't improve your safety at all and may have actually put you at greater risk in a high speed crash or roll-over.
However, that's just my opinion. Most people probably already told you it was "cool" so feel free to ignore me.
Here is a picture of a proper cage for future reference.
the bends look like they kinked, no crossbracing
most dragstrips techs will not allow you to run with that.
Is that a weld in the middle of the roof hoop? That won't fly with NHRA. Also the rear hoop bends just behind the seat look like they are not mandrel bent.
if you are fast enuff to need a roll bar no track is going to allow you to run with that....dragstrip or road course. as others said.... bars to small, bends are not done correct, no bracing and welding in middle of main hoop is a big no no. if it is just for looks ok but....
the pics added above are a good examplw of proper roll bar. welded to the frame...not bolted to seat mounting bolt. proper bracing, tube size and bends
I think it's important to make sure any roll bar/cage installed complies with the specs of the organization(s) you run in. I'm getting ready to install a roll bar/cage and I want to make sure it complies with NASA specs beforehand. I'll also check SCCA roll bar specs to insure cross-over compliance. Anyone can likely find these specs on line.
I'm not a drag racer but here's a link to HHRA roll bar specs:
not sure if it will work but you can copy and paste it and it should take you there. Its under southwest ncco number 30 page 22.
Thats not going to pass any inspection at a track. I'd yank it and use it as a dimensional template and build a new one that will meet spec. It might actually be more dangerous having that in than not if it were to bend in a bad way during a rollover.
I applaud your efforts, but that roll bar needs to be checked out by someone with experience. I see some issues, a few of which have already been mentioned.
It's your safety that's on the line here, so please have it checked out by a professional fabricator with race car experience before you put your faith in that setup.
I don't want you to feel like everyone is just taking shots at your fabrication skills. Hell, I give you points for recognizing that you may need a cage and trying to build one yourself. Many people focus too much on horsepower and don't give any thoughts to safety.
Here are some pictures from the recent cage improvement I made to my track car. The side bars and halo may not be needed for what your application is, but these pics might give you some ideas.
FYI, this cage is made of 1.75 x .120 mandral bent steel, welded to the frame. Notice the bends and the added gussets that triangulate the structure and help spread the load to multiple frame attachment points. No two-piece bars, no inserts, no bolts.
It's kind of like the story of the guy who wanted to buy a cheap helmet. The store owner told him: "Only buy a $100 helmet if you have a $100 head,"
When do I need a roll bar or roll cage, and what should it look like?
A roll bar is required in any convertible running 13.49 seconds or quicker in the quarter mile
Haven't been to the track in years and years, but I guess this is why you don't see too many time slips from C6 convertibles.
