ZO6 Radiator same as C6?
Old Mar 12, 2009 | 02:00 PM
SL33PER's Avatar
SL33PER
Default ZO6 Radiator same as C6?
Is the ZO6 Radiator the same size cooling capacity, rows, etc?
I know it does not have a built in trans cooler but thats ok.
Thanks.
Old Mar 12, 2009 | 02:15 PM
Stage Runner's Avatar
Stage Runner
Thanks.
I believe its the same, any capacity difference is minimal if any....call DeWitts.
SR
Old Mar 12, 2009 | 10:41 PM
Zteve's Avatar
Zteve
I've heard that the Z06 and the Z51 use the same rad, but the base c6 uses a thinner one. Not sure if its true or just rumor
Old Mar 13, 2009 | 07:17 AM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Thanks.
All C6 radiators were basically the same with only interanl coolers being the variable. Z06's are the only consistant version, which had an internal cooler on the passenger side for the rear end. The engine oil cooler (eoc) was an air type cooler in front of the radiator. Our model A05A would be for the Z06.
Old Mar 13, 2009 | 07:49 AM
EuroRod's Avatar
EuroRod
I use a Ron Davis 57mm unit with oil cooler. It fit perfect, and I've never had a cooling issue since I installed it with a 160 stat.
Old Mar 13, 2009 | 09:50 AM
SL33PER's Avatar
SL33PER
Thanks for the info!
To ZO6 Radiator same as C6?
