FAST epoxy?
I was thinking he could use some sort of plastic epoxy to seal it. Let it dry. And then use epoxy putty (Quick Steel) over that so it is double sealed. Quick Steel says it can be used on intake manifolds.
Let me know your thoughts.
Thanks,
Andrew
Thanks,
Andrew
For the BEST epoxies out there, I recommend McMaster-Carr; you can find the same type of epoxy material the manifold is made from there. I bought some of their fibreglass epoxy (3M Scotch-Weld 2-PART Epoxy Adhesive 1838 Green, 2-OZ Tube) for my railgun barrel, and it held together at 60,000PSI
http://www.ellsworth.com/display/pro...1&Tab=Products
so say if you put a good epoxy around the modded area to reseal it, will it be ok to put some epoxy putty on top of that to help create a 2nd layer/seal or is that overkill?
so will any kind of epoxy be able to stick and adhere to the Goop that is already on there to seal the back mod or will it not adhere to the Goop?
and is a clone of Shoe Goo. I would think underhood temps could reach 200* on a hot day, since IAT's can easily hit 150. I would happily bet anyone that you would never see Goop or Goo used under the hood of any Pro Racing Team car.
If its the wrong glue then why are there over a 100 of these in service for the last 4 years out there. The first one I ever did was on my car and the second was on Welcome2try's car. He sent his back to me to get refreshened and guess what.....nothing wrong at all with the back of the manifold where I glued on the graft.
I repair a number of manifolds that used 2 part epoxies that crack open at the rear after using the 'correct stuff' as you say.
I offered to fix the FAST in question for free once I heard it was one of mine. Now its a bash fest to say I use the wrong glue by all the pro's. If it was then where are all the failures? This is the second one I know of and both had oil (not heat) issues. I now seal the glue from being able to come in contact with the oil with an epoxy paint.
Anyone who got a fast prepped recently will find the glue is sealed against oil. The glue used needs to be able to flex to handle the constant vibrations on an engine. It cant be a rock hard epoxy. Lots of vendors/tuners use that type of adhesive and they crack and thats when they get sent to me.
All FAST's prepped by me have a lifetime garantee as I wouldnt leave anyone out in the cold with an issue even years after buying one. Not a sinlge part on your car has a garantee that good. I even extend the fix to people who buy them second hand. I've done so many for free for people who tried it themselves and it came out bad. I'm a nice guy and definitely didnt deserve what happened in this thread. I offered to the frined of the OP to fix it for free and instead what I got was a thread to bash the mod.
Whats the goal Siffert? To stop all FAST sales and make me look bad? Let me know what I have to do to be forgiven for my sins.
I wouldn't lose any sleep over this. I wouldn't hesitate for a second to have you prep a FAST (if I had one). Online forums are notorious for "expert" opinions. I wish you were closer, as I'd have you install one for me.
San
i wanted to keep the details of who did the FAST out of respect...
so please no arguing...
my buddy and i don't think it is an oil issue...last time we had it off of his car the intake looked good and it looks good now...
i have a few resolutions so this thread is over...thanks everyone for their input...
I have no resistence to making a better way to hold on a graft but I know hard 2 part epoxies will crack. The twin says to stop relying on the glue to hold the graft in place so all future grafts will be over engineered and held on with two screws to an internal plastic brace made from the same plastic and will use a soft pliable silicone to prevent the leaks.
Send the manifold to me and it will be repaired with an internal brace to bolt the graft in place and the sealant will simply act as a gasket and not a fastener. Problem solved. It will take another 15-20 minutes but its secure.
Anyone else wanting this update will be able to send the manifold to me for the update for free......even if its a manifold prepped by another vendor. The later case can simply make a donation to St Judes Hospital.
Siffert will be sending his FAST 90 for updating to both the rear graft and to update the porting to current levels.
After speaking on the phone, it appears we had a prior miscommunication and both of us were appologetic and willing to work together to solve any remaining issues including tuning.
As a side note, its important to realize that written communications are always second best to speaking on the phone. When there there is an issue, go to the source before it gets bigger.
To the OP who started this thread-I hope you got whatever you needed here and good luck getting your Fast going again.
