Totally different beast
Old Mar 16, 2009 | 08:15 PM
Boomer111's Avatar
Boomer111
Default Totally different beast
I have a base 08 with Z51 sways and FSD's. Great improvement right there. I had a Tunnel plate added (E2). Now this car really sits in the turns. Very noticeable difference rounding turn, feels like the front end has become lighter. But what has really happened is that the car plants in from the middle towards the rear, no twist. It is really a significant change. The FSD's were very noticeable improvement. The sways helped but I think the Tunnel plate has helped even more. Probably accumulative!
This is a totally different ride than what came from the factory.
Old Mar 16, 2009 | 08:17 PM
c6 batmobile's Avatar
c6 batmobile
The tunnel plate is great. I just did mine and I do notice a difference.
Old Mar 16, 2009 | 08:44 PM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
I installed one (E2) with insulation, it made a difference.
I retorque it last weekend, it was fine!!
the car seems a lot stiffer
Old Mar 16, 2009 | 08:48 PM
jxhunte's Avatar
jxhunte
I added Elite Engineerings Tunnel Plate with thermal ABS but didn't really notice any difference in handling. Just received the Z51 Sway Bars from Gene today and will install using the PFADT Poly Bushings within the next few days. I will let you know what I think of this combo once complete and I have a chance to test on our winding mountain roads.
Old Mar 16, 2009 | 08:59 PM
james1990's Avatar
james1990
where did you guys get the plate from?
Old Mar 16, 2009 | 09:12 PM
pmj341's Avatar
pmj341
Elite engeering, he's a forum vendor
great product
Old Mar 16, 2009 | 10:07 PM
Boomer111's Avatar
Boomer111
No doubt about it the car is stiffer horizontally. Car feels much tighter. By the way this was done with the addition of long tubes and while I love the sound/performance, the plate addition has really caught my attention. I was surprised.
Old Mar 17, 2009 | 05:54 PM
StoplightWarrior's Avatar
StoplightWarrior
I just did the z51 bars and pfadt bushings and definitely noticed an improvement
Old Mar 18, 2009 | 01:03 PM
CMY SIX's Avatar
CMY SIX
You are going to be AMAZED!!!!!!!! L.A.P.D. has a nice one too!{tunnel plate}
Old Mar 18, 2009 | 04:55 PM
marathon's Avatar
marathon
St. Jude Donor '09
Appears only 4 bolts per sway need to be removed to change the bars or am I missing something?
Old Mar 18, 2009 | 07:58 PM
marathon's Avatar
marathon
St. Jude Donor '09
ttt
Old Mar 18, 2009 | 09:00 PM
c6 batmobile
There is the two on the end that attach to the a-arm tie rod area.
Old Mar 18, 2009 | 10:44 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I hightly doubt the tunnel plate makes much difference on a C6. The C6 plate is allready solid aluminum. On the C5 the OEM plate is stamped metal so there is some advantage, but it's very minor.
I recently took mine off and sold it and went back to stock as I'm putting my Z06 back to stock. I felt zero difference other than the fact the tunnel gets warmer w/o the heat reflective barrier.
To Totally different beast
