Ventureshield
Old Mar 20, 2009 | 04:33 PM
slavine's Avatar
slavine
6th Gear
Just wanted to let you know that I just had my Venture Shield installed today and it went perfect. I had the hood, bumper, mirrors, fenders, and lights and it looks great. Thanks for all your tips and information. I did look at the installers other work and it was on all high end vehicles and they all looked good.
Old Mar 26, 2009 | 07:55 PM
LMBC6Brian2's Avatar
LMBC6Brian2
Get it off those headlights. It will get to hot with the hid lights and small cracks on the plastic covers will form and you will be really pissed. Take it off them asap. No joke.
Old Mar 26, 2009 | 10:04 PM
GeorgeL98's Avatar
GeorgeL98
After reading this thread, I just might be interested in the VentureShield. Does anyone know of a good installer in the North East, more specifically the NYC area???
-George
07 Z51
Old Mar 27, 2009 | 11:17 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Its on my headlights and so far, no problems with cracks or anything that's been reported. I did note that those with cracks were using the tinted products. My thought there is that the color may be trapping the heat therefore inducing the crack problem. I'm still watching closely and should I see even one crack, mine are coming off in a flash. They've had the VS on them for the past 2.5 years and so far, I'm ok.
Old Mar 27, 2009 | 12:43 PM
95blklsc's Avatar
95blklsc
I highly doubt, actually I would put money on it that the crazing is due to heat. The spiderweb cracking is not from heat otherwise everyone who lives in Florida or Arizona would have cracked headlights. It is more likely from the type of solution used to install the headlight covers. Diluted IPA is usually used to install (http://en.wikipedia.org/wiki/Isopropyl_alcohol) which can cause the polymer chains to start to separate and cause the crazing. Do if you have them installed make sure your installer uses an alternative solution or just distilled water.
Old Mar 27, 2009 | 03:27 PM
LMBC6Brian2
It happened to my car and my buddies car. Also, my car stays in the garage and only sees about 2k miles a year. It was a costley mistake, and the worst part is my installer TOLD me not to do it. I insisted on it and he was right. He was nice enough to give me a discount on my wifes car though. Trust me, it can happen.
Old Mar 27, 2009 | 06:50 PM
95blklsc's Avatar
95blklsc
What did your installer use for solution to install them?
Again, heat build up isn't the problem, if it were sitting in the sun in the summer on a black car would get the lenses hotter than the heat from an HID bulb behind a projector.
How long after installation did the siderweb cracking appear?
This could also be a result of molded in stress.....
Old Mar 27, 2009 | 08:03 PM
dgrant3830's Avatar
dgrant3830
You certainly make a good point. Mine were put on with a soap based spray solution as I watched them do it and asked what it was at the time. I mentioned alcohol to them but they said they never use it.
Old Mar 27, 2009 | 09:27 PM
95blklsc's Avatar
95blklsc
It could simply be the adhesive used on the back of the film, I certainly won't shoot that down.
Old Mar 27, 2009 | 10:57 PM
Jim_H's Avatar
Jim_H
My car has VS on the headlights, three years, over 20K miles including a cross country trip with lots of night driving and no sign of any kind of damage.
Old Mar 27, 2009 | 11:04 PM
hbutts1's Avatar
hbutts1
Originally Posted by Texas_Venom
Interesting. There is not many reputable isntallers that will make that claim. 3M has so much orange peel that it does not look good. VS Ultra doesnt have any...
And yes 3M has a much stronger adhesive. But I dont think that is really a player here when the film is warrantied from peeling. 3M 5 years, VS lifetime. That really strong adhesive could be a factor when you have to remove it someday... you wouldnt want to pull the paint.
I too have VS on a black car!! Made it to the east coast yet? Anyway, installer is critical especially on black!!!
Old Mar 27, 2009 | 11:23 PM
HANNY's Avatar
HANNY
i am getting the venture shield done as we speak, the installer i had a long conversation with. he appears to know his stuff. he said he has used all the different types and gone with ventueshield (for what thats worth). one interesting thing he did say is he called me off once on the install and wanted to wait for his next shipment. he says they not every shipment of the stuff he gets is perfect. dont know if thats true just passing that second hand info along. paul
Old Mar 28, 2009 | 08:58 AM
  #33
akriggm's Avatar
akriggm
hanny,
I had my 2009 done yesterday by the same VS installer that did slavine's and he did a phenomenal job. However, there was a small patch on the top of the front bumper that wasn't settling properly. He pointed it out to me (hard to see on a cloudy day) and said it might be a fault in the material (which he has seen on occasion) and if it doesn't settle out over the next week, he'll redo that section at no charge. The rest of the job is flawless, so the key is getting a good installer that will stand behind the product!
Enjoy,
akriggm
Old Mar 29, 2009 | 11:13 AM
  #34
hbutts1's Avatar
hbutts1
I agree, no problems yet!!
