I have an 05 C6 M6 base, I am getting Z51 sway bars w/ Pfad bushings and was thinking about also getting Bilstein Sport or HD ( I still cant figure out which ones i should get, everyone has different opinions on this??)
My question is this, would getting Z51 springs be worth while? or will my base ones be fine? And if so any instructions on how to install them?
If you want to try Z51 springs, I have a set that I just removed (replaced w/ coil-overs) that I would sell you cheap. I ran them with Bilstein sports on my track car. Great Combination!
the rear rates are so close, you wouldn't notice a difference
the front rates are significantly different...but keep in mind that the stiffer Z51 springs will affect ride more than the swaybars do...ride-wise, you'd only notice a stiffer bar when only one wheel hits a bump...with springs, all the imperfections that both tires are hitting simultaneously will affect ride as well
thanks, so if I stay with base, should I get the Bilstein HD or Sport? I don't want to have the "busy" feel in the car when taking corners, but I don't want the feel to be sloppy either, any ideas on what a good setup would be?
I also have a Base C6 and upgraded to Z51 sway bars/Bilstein Sports on Base springs. IMO - The ride was kind of bouncy and not in full control. I just had the Z06 springs and PFADT sway bar bushings installed along with a wheel alignment. Now, the car handles really well and feels "connected" with the road. The ride is pretty firm, but comfortable for me.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
I have an 05 A4 with 3.15 gears. The Bilstein HDs did the trick for me as I was experiencing a bit of wheel hop in cooler temps. I have not noticed much of a difference taking corners.
Since you mentioned Z06 springs, for rate comparison purposes:
The best spring and sway combination I found when using the base springs was the Z06/Z51 F bar with the base R bar.
As already noted the base and Z51 R spring is nearly the same. The larger F bar compensates nicely for the softer F base springs. The ride, I felt, was better with the base springs but needed the added sway control offered by the larger F bar.
The car hooked very well in autox on 710s. The larger Z51 and Z06 R bars made the car too loose for my driving style.
I've had a 05 z51 and now have an 08 w/ the base setup and just added z51 sways last year. The z51 has a significantly stiffer ride. I prefer the base setup with z51 sways. I think its a perfect balance. I autocross 2 times a month and do quite well. People do comment how well the car rides. With race tires I regularly pull 1.25g in the corners.
Shocks are up to you.
--Dan
Very interesting. I take it you track your car. Does your track experience include very high speed? If so, with the combo you recommend, does the car tend to push any? Are there any downsides? I keep hearing many just install the R Z51 bar. More driving/racing thoughts on this combo appreciated.
I only ran the combinations for autox and used C6Z06 shocks at the time. I moved on to Pfadt COs, sways, and camber kit as I wanted more adjustability as the car is also my DD. I run the Pfadt Street Sways on full firm F and full soft R. With my A6 I mainly left foot trail brake to rotate the car so the soft R bar works for me.
