wont go into competitive mode
Old Mar 19, 2009 | 06:17 PM
FaSStC5's Avatar
FaSStC5
Default wont go into competitive mode
so i tried putting my car on the competitive mode option and it wont go it just goes to traction on and off , and it use to do it before?
Old Mar 19, 2009 | 07:19 PM
BEZ06's Avatar
BEZ06
What have you recently done different?
Did you put new wheels or tires on the car with new sensors? If so, they need to be programmed to the TPMS.
Are you running with no sensors?
Bob
Old Mar 19, 2009 | 07:28 PM
BEZ06's Avatar
BEZ06
Never mind.
I see we answered your questions in that other thread.
Just get sensors and program them as in the video below.
Bob
Old Mar 19, 2009 | 08:55 PM
FaSStC5's Avatar
FaSStC5
Originally Posted by BEZ06
Never mind.
Bob
so once i install the tps and prgram them the competitive mode will then work?
Old Mar 19, 2009 | 09:07 PM
BEZ06's Avatar
BEZ06
Yes.
The sensors and TPMS are a great system - they are there to protect you, especially when running with runflats that just don't give any handling feedback when they lose pressure, at least when you're going straight down the highway. If you lose pressure while cruising down the interstate and don't know it because you don't have sensors, when you try to take the off-ramp at your normal cornering speed, you'll probably end up in the guard rail when a sideload builds up and you lose control.
If sensors or the TPMS aren't working or the sensor aren't programmed properly, you won't be able to go into Comp mode or turn AH completely off.
Bob
Old Mar 20, 2009 | 12:02 AM
Slwsvt's Avatar
Slwsvt
I have the same problem. I took my Vette to get an HP tune local and the shop said they had upgraded GM programming for my 05. They added the most current upgrades and ever since then my Vette will not go into competitive mode. It only turns the traction control off and on. No other changes when this started happening. BTW I decided to not have that shop adjust my HP tune.
To wont go into competitive mode
