radio
Old Mar 20, 2009 | 01:02 PM
r-u-vett's Avatar
r-u-vett
Default radio
I need help guys. My radio turns on but no sound. what could it be.
Old Mar 20, 2009 | 01:40 PM
glennhl's Avatar
glennhl
Blew the fuse to your amp? Had this trouble on another car, head unit came on but no sound until I replaced the fuse for the amp.
Old Mar 20, 2009 | 02:08 PM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
That happened to me once or twice. I have nav, I just turned the radio completely off then turned it back on again & it worked fine.
Old Mar 20, 2009 | 02:14 PM
r-u-vett's Avatar
r-u-vett
checked fuse and turnd off radio, nothing
Old Mar 20, 2009 | 02:34 PM
Keencutter's Avatar
Keencutter
Mine in my '07 does that sometimes. I turn it off and back on and it usually works. Mostly on FM stations.
Old Mar 20, 2009 | 02:39 PM
r-u-vett's Avatar
r-u-vett
nothing, I check the amp fuse and it looks ok also changed it with another,(nothing) also turnd the radio off and on nothing.
Old Mar 20, 2009 | 04:15 PM
Vito.A's Avatar
Vito.A
I followed the Diablo instructions and pulled the radio fuse to load a tune. Afterward my radio would not turn on. I double checked the fuse and everything was fine. After the car sat overnight it magically worked.
You might also try disconnecting the battery ground for 10 seconds and reconnecting it.
Old Mar 20, 2009 | 05:02 PM
r-u-vett's Avatar
r-u-vett
Thank I'll try that...
Old Mar 20, 2009 | 05:11 PM
r-u-vett's Avatar
r-u-vett
well I disconected the battery and no luck,,,,
Old Mar 21, 2009 | 04:54 PM
r-u-vett's Avatar
r-u-vett
come on guys, help me out. I need to fix this i'm going crazy without my music.
Old Mar 22, 2009 | 01:04 AM
glennhl's Avatar
glennhl
Trade it on a C6 and it will work!
Sounds like maybe your amp quit working for some reason.
Old Mar 22, 2009 | 03:11 PM
r-u-vett's Avatar
r-u-vett
where is the amp located?
Old Mar 22, 2009 | 09:34 PM
glennhl's Avatar
glennhl
Don't know about a C5, but I think it's under the passenger seat on the C6.
To radio
