Catch can Question
Old Mar 22, 2009 | 04:51 PM
JRLedFoot's Avatar
JRLedFoot
Originally Posted by SpinMonster
All correct.
You run a oil cap breather and a breather on the top of the catch can.
Once you make big HP, you will be pulling in way too much oil. Cartek put the breather on my car and stated they use it on all cars north of 450rwhp.
I use no oil between changes so the blow-by theorists are wrong. You will not get more blow by or a better statement would be that you will be burning less oil in the combustion chamber. I have had my heads off 4 times since the breather set-up went on my car and the psitons are so clean compared to before it. Carbon is a bad thing. If there was substantially more blow by, the pistons would still be dirty...they arent.
Please forgive the stupid question:
I understand everything else but,
How is the breather installed onto the top of the catch can so as to turn it into a breather can?
So,I can buy the catch can & convert it into a breather can, is that right?
again,sftsq.
JR
Old Mar 22, 2009 | 05:16 PM
gm4life's Avatar
gm4life
Originally Posted by nwc6
As stated, I get between 1-1.5oz of oil out of the can every 1500 miles or so. So the can is catching some, but not all the oil mist out of the crankcase. I have see some pictures of manifolds with actual puddles of oil in them.. I know some guys in C5's were running two cans in series, others have come up with systems using air/oil separators from air compressor systems..
I run a catch can on mine reduced the oil in the intake but not all of it. I had puddle of oil behind the TB and film of oil in the intake before the can, with the catch can it was reduced down to just light film of oil in the intake.
Old Mar 22, 2009 | 05:57 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
The catch can is not 100% ineffective, as previously cited (At least the can I've got). The Elite Engineering catch can has a special stainless steel maze and filtering design built into the top section which traps oil vapor and lets it condense into droplets that collect in the can. Additionally the outlet at the top is designed to prevent sucking any collected oil from the can into the intake. If it was just an empty can, then it probably would be ineffective, especially for high output engines.
My can probably lets some amount of vapor to get through, but it sure isn't 100% ineffective.
Old Mar 22, 2009 | 06:22 PM
siffert's Avatar
siffert
Looks good to me. Not cheap but Elite's goods are generally well engineered. I got their gas pedal and after a few tweaks to it, works great.
http://eliteengineeringusa.com/C6Catch_Can.html
Old Mar 22, 2009 | 06:24 PM
gm4life's Avatar
gm4life
^^I run the same catch can.
Old Mar 22, 2009 | 06:53 PM
SpinMonster's Avatar
SpinMonster
Catch cans catch 10% of the oil...they are inneffective based on my using lots of them and then removing heads to see the carbon deposits. I have had my heads off 4 times and saw the difference.
Try taking off your throttle body and taking a nice paper towel and just wipe the plenum area of your intake manifold to see if tis effective. If it is then ok, but my feedback from users of your can said it wasnt much better. ZERO oil in the intake is available with a breather can. I like ZERO in there after seeing it on my car.
The difference when I went to a breather can was astounding.
Old Mar 22, 2009 | 07:40 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Who is the supplier of the breather can you use?
Old Mar 22, 2009 | 07:49 PM
Poppy's Vette's Avatar
Poppy's Vette
I don't want to have to fab something up. I'm not that clever. Is your system plug and play? I did find oil film in my TB and intake when I recently had Spin port them so I would like something better if it's not something to complex I have to mess with. If it is, I will at least put my catch can back on with my modification to make it easier to drain.
Old Mar 22, 2009 | 11:35 PM
JRLedFoot's Avatar
JRLedFoot
again,sftsq.
JR
Wow,
Not even a or
I can take a beatin, but to be completely ignored, ouch.
That's ok,I'll figure it out.
Thanks anyway.
JR
Old Mar 23, 2009 | 04:13 AM
SpinMonster
again,sftsq.
JR
http://www.competitionmotorsportsonl...er-Tank/Detail
Old Mar 23, 2009 | 04:14 AM
SpinMonster
or
http://www.jegs.com/p/Moroso/750108/10002/-1
You will have to buy a T-fitting to input a second hose line.....if thats what people think fabrication is I need a drink.
I actually have a second welded input line on the tank.
Old Mar 23, 2009 | 04:20 AM
SpinMonster
Wow,
Not even a or
Thanks anyway.
JR
I would give people a day or so to respond especially on a weekend.
Old Mar 23, 2009 | 08:21 AM
  #33
JRLedFoot's Avatar
JRLedFoot
Got you.
Thanks & I appreciate your patience.(It's a virtue I'm lacking in)
regards,
JR
Old Mar 23, 2009 | 08:55 AM
  #34
jcase10's Avatar
jcase10
St. Jude Donor '10-'11
I would assume LS3 have similiar issues. Any 1 care to respond with experience on the LS3's? Ready to buy breather, but would like input on oil/intake first.
Old Mar 23, 2009 | 01:40 PM
  #35
nwc6's Avatar
nwc6
LS3's are plumbed the same as LS2's, so yes the same problem is there. I have a LS3 so you can reread that I found a slight amount of oil in the intake, even using a can.
Using Spins can, the crankcase vapors are routed to the can, period. There is no way for the oily vapor to enter the intake tract.
With the stock system, you are using manifold vacuum to pull those vapors into the intake manifold. The hose on the accordion coupler is in front of the throttle body and supplies fresh air (make up air) to the crankcase.
Now for the question I have.. Does the fresh air in the crankcase help prevent build up of acidic or corrosion causing vapors in the crankcase? Is this system one reason we can go so long between oil changes, because we are reducing the buildup of moisture and nasty vapors in the crankcase?
Old Mar 23, 2009 | 02:33 PM
  #36
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
I would add to the above post that the SpinMonster system essentially destroys the integrity of a PCV system and reverts to the old pre- emission control days when engine crankcase ventillation systems were simply a vent pipe coming from the valley cover to a breather cap which was open to the atmosphere, basically allowing any crankcase vapor/blowby to escape to the atmosphere. Smog control laws since then have outlawed releasing those emissions into the atmosphere, hence the requirement for a Positive Vent Control (PCV) system tied to the intake.
So, if your need is to stay legal, SpinMonster's system wont cut it.
Old Mar 23, 2009 | 03:48 PM
  #37
SpinMonster
True.
Also keep in mind while we are on the subject of 'legal' that all header systems are illegal since the move the cats from the factory location in violation of federal law. Also, the use of any tuning of the rear O2 sensor codes to keep from getting a check engine light also violates emmissions testing as they are listed in the OBDII check status for emissions testing. Most tuners delete this code. 37 states now recongize after market mufflers as an equipment violation and are summonsed by local authorities. Even Z06 mufflers on a non-Z06 are a violation. It has to be the one the car was made with here in Colorado.
Burning oil in the combustion chamber does increase emissions. I never got the point of decreasing crankcase emissions while burning a dirtier combustion mixture as clean but so be it. The better system was actually measuring the emissions from a vehicle but now its all OBDII and thus, any alteration of the original tune is a violation if it changes the number of checked fields.
Case law that helps: In the event a state certified service center says your vehicle passed the emissions test they also certified for use the way the car was set up at the time of testing. So if the test center passed you with moved cats, your car is authorized to use cats in the new location for that year.
To Catch can Question
Old Mar 24, 2009 | 12:02 AM
  #38
SL33PER's Avatar
SL33PER
All correct.
So are you saying all you are using is the breather in the oil cap?
Old Mar 24, 2009 | 12:55 AM
  #39
SpinMonster
You quoted me and the exact quote is right there on line 2.....a breather can AND and oil cap breather. All you need is the breather can though.
Old Mar 24, 2009 | 02:45 PM
  #40
SL33PER's Avatar
SL33PER
Cool, Thanks! I was a little confused by the picture.
