MUSTANG DYNO vs DYNOJET
Does anyone know the real deal??
I saw a bone stock 2007 Z06 only make 350 RWHP on the mustang dyno using Hp tuning software by extreme professionals.
Another Shop ( Corvette Center ) also told me that the C6 bone stock Z06 #'s are pretty bad even on the Dynojet.
The biggest/best thing a Z06 owner can do is TUNE thier car.
having that said im happy with my C6. Windows down, Top Off.
BUT What's the real dyno story here! On a dynojet, I make SAE of 439.7 RWHP w/cam, exhaust,and callaway honker. I'm looking into porting the intake manifold, throttle body, intake runners, MAF sensor, then re-tuning on a mustang dyno. Any thoughts or knowledge on this...
Another Shop (Corvette Center) also told me that the 05'-09' bone stock Z06's #'s are pretty bad - even on the Dynojet.
Having that said, I'm happy with my C6 Coupe. Windows down, Top Off. A Few bolt-Ons and Faster...Yeah (Compared w/ STOCK Z06)
BUT What's the real dyno story here! On a dynojet, I make the SAE of 439.7 RWHP, that's w/cam, exhaust,and callaway honker. I'm looking into porting the intake manifold, throttle body, intake runners, MAF sensor, then re-tuning on a mustang dyno. Any thoughts or knowledge on this...
http://www.msprotege.com/forum/archi...123629978.html
BJK
BJK
The correct answer is "inertia and absorbtion" where "inertia" stores the energy as kinetic energy and "absorbtion" dissipates the energy as heat. The inertia method could return the majority of the energy from the engine as power whereas the absorbtion method converts it directly to heat...regardless of the mechanism used, both provide a load to the engine.The third paragraph where he describes the method used by inertia type dynos to calculate HP contains gross errors. He states accelertion is used to make the calculation which is true to an extent since it uses the change in velocity WRT time which is the definition of acceleration. But then he proceeds to say they use F=mA where the mass is known and accelertion is measured so HP can now magically be calculated...a pretty neat trick since F=mA is the formula for translational motion. The inertia method requires a solution involving rotational motion since the drum is rotating.
It is in fact done by measuring the amount of kinetic energy added to the drum divided by the time it took to add the kinetic energy...a very simple and elegant solution to very accurately measure HP. The funny thing is that Mustang dynos have a portion of the HP determined by the inertia method and a portion determined by the absorption method which means it has two components of error to contend with. Not exactly the best way to accurately measure HP. The advantage of the Mustang and all other absorption dynos is the ability to control the rate of acceleration (and even hold RPM constant with most engines) for purposes of tuning. But Dynojet now makes absorption type chassis dynos that combine the inertia/absorbtion methods like the Mustang to allow better tuning.Whoever really wrote this article has no clue as to how a dyno works or how correction factors are applied but seems more interested in discrediting Dynojet dynos. I cringe every time I see that link and am reminded that anybody can put anything they want on the internet no matter how much BS it contains. I don't mean to come across harshly, but articles like this are the root cause of the general public being misinformed as it gets regurgitated over and over until the BS is accepted as fact because it's heard so often.
