Can I get engine error codes from DIC on C6
Old Mar 23, 2009 | 03:39 PM
drbenne's Avatar
drbenne
Default Can I get engine error codes from DIC on C6
My question is if there is a way to access the engine error codes on the c6. I can get them from my C5 on the DIC by a series of dash button/key manipulations, but I don't know how or if it can be done with the C6. My Z06 engine light keeps going on. I go to the dealer and the cat converter is tripping a code. They replaced it once and now say it is a software issue they are working on. Knowing the code would save me going to dealer every several mos to have them reset it until a more permanent fix is available.
Old Mar 23, 2009 | 03:45 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
nope
Old Mar 23, 2009 | 04:05 PM
HITMAN99's Avatar
HITMAN99
If the code only happens every now and then it's EZ to reset. Just pull the ECM fuse (clearly marked on the fuse box lid), wait a few seconds, and replace. The code will disappear.
This happens often on cars with headers.
Old Mar 23, 2009 | 04:14 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
You need a code reader to get those codes.
They eliminated DIC code reading in the C6!
Old Mar 23, 2009 | 05:37 PM
VET4LES's Avatar
VET4LES
To Can I get engine error codes from DIC on C6
