Harmonic Balancer
Old Mar 24, 2009 | 02:29 PM
herbie1057's Avatar
herbie1057
Default Harmonic Balancer
I have a 2005 and have had the harmonic balancer replaced twice in the past 6 months. I know that early '05 had an issue with the bolts backing out which leads to catastrophe. But why is my car eating through balancers?
Old Mar 24, 2009 | 02:58 PM
knkali's Avatar
knkali
tell us more what is going on
Old Mar 24, 2009 | 09:20 PM
dbradley's Avatar
dbradley
They're either not installed correctly or the crank got messed up with the first one coming off.
Old Mar 24, 2009 | 11:38 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
Old Mar 24, 2009 | 11:42 PM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
you should have them pinned, so they don't slip, also how about a hardened bolt like ARP,instead of the stock bolt.!!!
Old Mar 24, 2009 | 11:55 PM
Wayne O's Avatar
Wayne O
CF Senior Member
Why GM ever changed I don't know but I believe all of the Gen III and Gen IV V8 engines use a press-fit damper with no keyway. This has been the case since the LS1 was introduced in 1997. As mentioned, pinning the crank would be the most worry-free solution.
Are you always using new torque-to-yield bolts? These bolts can't be re-used or they're destined to fail.
You don't have a supercharger do you? Supercharged applications should always pin the crank.
As noted, the harmonic balancer was a problem with very early 2005's. I believe they went to an integral diamond embedded friction washer as a production part in the 2006 LS2 and LS7 (and I suspect in the late model 2005's as well). I'd make sure you're still not using an early 2005 crank-pulley. Good luck!
Old Mar 25, 2009 | 07:41 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Are they working loose or is the rubber "coupling" failing?
Two different failure modes.
Old Mar 25, 2009 | 08:56 AM
knkali's Avatar
knkali
not enough info from the op
Old Mar 25, 2009 | 11:56 AM
herbie1057's Avatar
herbie1057
The car is still under the warranty so all the work is being done at the dealer. With this being said the car is stock and the HB is being installed to factory/dealer spec with new hardware. I took the car in the first time when my car shredded the belt. They replaced the HB and sent me on may way. The second time the car had a squeak belt sound so I attempted to lubricate the belt with belt lube and when that didn't work I took it to the dealer. Once again they said the HB was wobbling and wanted to replace it again. Thats about all the info I can send your way now. I will add more info when I get my car back from the dealer and actually see the invoice for the repairs
Old Mar 26, 2009 | 11:32 PM
kelp's Avatar
kelp
The rubber coupling is known to fail. I was at a corvette shop recently and they had failed HBs all over the place.
To Harmonic Balancer
