Density Altitude. It's how dense the air is, the more dense the more power an engine will make. You can do a google search for "density altitude calculator". Values to enter are barometric pressure, temperature, relative humidity, and field elevation. The result will give you a value in feet relative to sea level standard (baro pressure of 29.92 and 59*F, zero elevation). A negative value means the air is so dense you are below sea level. Some areas, particularly the northeast, regularly see DA in the negative thousand's of feet. Other areas see very high DA.
Found this site on Google. Thanks for the response.
Basically the lower the number of D/A the faster 1/4 mile time you get. Which is why guys in the midwest consistently see worse numbers than those on east and west coast.
I know how you feel, Phoenix is about the same as Oklahoma City. But at least Houston is less than 7 hours due south of you. Take a trip in the winter down to Houston and you will definitely get your PB.
Yes. You can figure about .10 gained for every 700 to 800 DA change. So if you did a 12.10 at +1,000 DA and went somewhere where the DA was -1,000, the 2,000 DA swing (2000-700=3) would give you an approximate 11.80, all things remaining the same other than changes in the altitude/weather.
I use it all the time. Though the Atco boys claim its bs cuz the weather there is never what Drag Times claims. Its like there is great negative DA in Atco, NJ, just never when they are running there! Yet Drag Times DA of MIR is always pretty much spot on, even though there isnt a weather
station near MIR.
hmmm....so my times in WA will be better than what i ran in WI and NC according to that thing. on the same day for the 3 drag strips (pacific, great lakes, and fayetteville respectively) i got:
-91
808
1100
haha, so the -91 is the best?
That is correct. The diff between +1100 and -91 is about .15 seconds
in the 1/4 mile, all else being the same.
It gets plenty cold at tracks such as Milan and Gateway, all those Great Lakes cold fronts...it's often very cold in the Chicago area. Southern midwest less so of course.
The tracks are at a little higher elevation of course but they do get crisp cold air and high barometers just like the East and West coasts.
Now if their tracks don't open as early in the season or stay open quite as late in it then that's unfortunate but it has little or nothing to do with who gets better air/more cold fronts/more high pressure systems on average. The physical altitude of a particular track is not variable of course but a cold day at a 400 foot track quite often still provides a lower DA than a hot day at an 80 foot track does.
And of course everyone is still free to roam about this great nation of ours and try out all sorts of tracks/locations if they don't like theirs, some have even done just that, just ask siffert LOL.
station near MIR.
It was a DA of -400 at Atco today (3/24) at around 4:25pm (though it was much lower earlier in the day), this is an irrefutable and undeniable fact verified by three separate high dollar weather stations and the track's officials/tower themselves.
I'm curious what the sources that you rely on happen to claim, while you're reading them from your location many hundreds, maybe even thousands, of miles away from Atco of course.
It was a DA of -400 at Atco today (3/24) at around 4:25pm (though it was much lower earlier in the day), this is an irrefutable and undeniable fact verified by three separate high dollar weather stations and the track's officials/tower themselves. I'm curious what the sources that you rely on
There is nothing irrefutable or undeniable that is was a -2200 to -1200 DA at Atco today.
Here was the DA at your 11.75 ride today at 4:00 pm. It was -2200 at 10:00 am at Atco. Confirmed by Accu Weather below too.
I find it hilarious that both of these are always highly accurate for everywhere in the USA except for Atco Dragway, NJ.
ps-any "high dollar" weather station can be easily edited to give higher DA by simply editing the altitude setting to a higher altitude. Voila, instant higher DA all day.
I think the Atco boys are simply embarrased by the terrific negative DA always there. Most C6 Fast records are set at Atco and most Z06 fast records are set at MIR. Duh!
The east and west coast not only have the benefit of elevation but have the benefit of more mild and consistent weather. Last week or so it was 86 one day and 36 the next. Im originally from california and weather like that doesnt exist. The d/a is consistently better at east and west coast tracks. Thats the point Im trying to make. Im not saying I dont ever get good d/a. I personally never get to run with a good d/a due to my job (active duty air force) and lack the ablility to travel at will due to the same circumstances.
I agree and would hate to break hundreds of miles away from home w/o a trailer.
Our track just opened, it's actual altitude is 5,300 feet but the DA for my runs went from 6,800 feet to 7,300 feet by mid afternoon. Made my 566 SAE rwhp Vette have only an actual 442 to the wheels.
atco is a 30 minute ride south and east of mt.holly and that weather graph is from the 23rd
Good catch. Plus they have Firebird at 1082 feet when it's actually 1240 feet.
Every foot of altitude is equal to about 1 DA. Thus if Atco is really at 99', the diff is only 60 DA at 37'. They have MIR correct at 87'.
Well, it says the 23rd but after midnite it is for the 24th. Here ya go for the 24th afternoon (then goes into the 25th) which is confirmed by Drag Times too. As you can see, its the same data I posted before.
