Service Charging system light...
Old Mar 26, 2009 | 03:34 AM
tractionlessvette's Avatar
tractionlessvette
Default Service Charging system light...
So i saw a post on this but a diff problem then mine.. My batt volt at idle is about 13 and while driving at 14.. Checked alternator and batt and they are fine.. no check engine.. however this happened twice in one month where at a stand still the idle dropped where the car was about to die.. Could that be the ETC, electronic throttle control, on the throttle body?? Not in the mood of buying a new throttle body for 500 bucks and that not be the problem..
Old Mar 26, 2009 | 10:39 PM
tractionlessvette
no takers??
Old Mar 29, 2009 | 12:45 AM
tractionlessvette
guess ill buy a new throttle body
Old Mar 29, 2009 | 10:25 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I seriously doubt that its a TB issue. Check your battery terminals for proper tightness. Your getting a charging system fault. The power out of the alternator comes out of the field terminal in the rear of the alternator and then it goes to the terminal on the starter solenoid. From there it goes to the battery. Check all of those connections for a cood clean and tight connection.
BC
Old Mar 29, 2009 | 10:43 AM
dennis50nj's Avatar
dennis50nj
seems normal to me, the fan could have cam on with all the lights brake lights sitting at a stop can drain the battery voltage down a little
Old Mar 29, 2009 | 01:40 PM
VET4LES's Avatar
VET4LES
BC
Old Mar 29, 2009 | 11:05 PM
tractionlessvette
Originally Posted by VET4LES
i was thinking that if my batt has and holds power then its fine.. and the alternator generates current at 14v so thats fine.. doesnt that meant that my electrical lines are fine??
To Service Charging system light...
