1/4 track
Old Apr 1, 2009 | 10:50 AM
05 silver c6's Avatar
05 silver c6
Default 11's with an 2005 a4 real tough
I have the same car
Best run 12.89 @ 109
Street Tires
Tune
CAI
3.42 Gear
Corsa
Now with the vortech 522 RWHP 472 T
Street Tires (spinning all the way down the track)
12.01 @ 121
Still do not know how to get it down the track with the SC as you can seen by my times however, prior to the SC I was able to get virtually no wheel spin and a 1.9 60foot.
Old Apr 1, 2009 | 10:53 AM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
3200-3400 stall converter and 275/40/17 Mickey Thompson drag radials should get you into the 11's easily.
Old Apr 1, 2009 | 11:31 AM
siffert's Avatar
siffert
Originally Posted by 05 silver c6
Now with the vortech 522 RWHP 472TQ. Street Tires (spinning all the way down the track)
12.01 @ 121
What dont you understand? You got 500+ hp and wondering why the runflats cant handle it? Its simple-they can barely handle 375 rwhp. You need to get yourself some 17" or 18" Drag Radials/Wheels and then you'll stop spinning down the track and probably pick up another .5 second at the same time
Old Apr 1, 2009 | 05:44 PM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Originally Posted by c6 batmobile
Your car does pull harder from 1/8 to 1/4. I agree with dropping your tire psi but the burnout should only be slight on a stock run flat tire. A burn out on these will heat them up but it will make the slick as hell too (ask me how I know). A good set of d/r's a tune and some headers will have you kicking some serious butt.
I know how you know too as I have gone down the track sideways too. Then again cold tires also do the same thing once you shift second so you have the choice of sideways off the light or sideways shifting to second. (the A4 hits the tires harder at the shifts than the A6.....as Marc and I found out one cool day )
The quicker guys would let me heat up the track for hem and watch to see which wall I could hit ...... now hat I have smartened up a bit I wait until they lay some rubber down and then chew it up...... I have consistently run 12.40s with only a CAI and the stock run craps!
Drag radials will do the trick
Old Apr 1, 2009 | 05:45 PM
Tommy D's Avatar
Tommy D
Actually a 2800 will too
Old Apr 2, 2009 | 08:56 AM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
Originally Posted by Rob01C5
How do you figure?
with his MPH he should be able to get into the 11's, provided he hooked!!
Old Apr 3, 2009 | 06:59 AM
07 Z51's Avatar
07 Z51
He will also pick up a ton in the trap speed. I have a bolt on LS2 (385 rwhp) that traps 120 mph in the 1/4 mile at 12.02 sec. Short time on Supercar RFs is 2.0. He is not getting the power to the ground - there has to be a lot more in the 1/4 mile time and mph department for this guy. Do the Spinmonster Mod - I am in the process of doing the same.
Old Apr 3, 2009 | 08:47 AM
siffert's Avatar
siffert
Yes, I know he was not getting power to the ground and that is why I recommended DR's (Drag Radials) for the track...an age old proven solution. So what, pray tell, is the "Spinmonter mod" which apparently you claim as "the do all solution" for traction. This ought to be good.
Old Apr 3, 2009 | 09:10 AM
dennis50nj's Avatar
dennis50nj
im not having any traction problems with three diferent dr brands or 6 diferent sizes
Old Apr 3, 2009 | 03:39 PM
Tommy D's Avatar
Tommy D
OMG....... Are we now naming mods form members hey why fool around I want the Dennis50NJ Mod
Old Apr 3, 2009 | 03:47 PM
lockshed's Avatar
lockshed
I have the same car
Street Tires
Tune
CAI
3.42 Gear
Corsa
12.01 @ 121
What was your 1/8 time. I did 7.63 at 93 in the quarter with a 5-6 pound boost procharger, kooks, stock 3.15's, a4 and run flats. At the time rated 489 RHWP. Some runs I got traction, some I didn't. But I ran with track control on, when I took it off I would hit the rev limiter. Also started in drive, foot braked and played with flooring it and sometimes half way on the gas until green and then mashing. Also, if I tried to shift the automatic, I usually hit the rev limiter also. Just my two cents.
Old Apr 3, 2009 | 04:34 PM
siffert's Avatar
siffert
I want the "TommyD Stall Mod".
Though some of them can be quite infamous too, like that "Fast w/Goop" mod.
Siffert wants to be known for the "Have Negative Da, Will Travel" mod.
Old Apr 3, 2009 | 04:52 PM
  #33
Tommy D's Avatar
Tommy D
Just think about the cost effectiveness of that Mod! Where can you get 3 tenths, take a scenic trip, meet a bunch of great gear heads and have a great time for about $ 500.00
Old Apr 3, 2009 | 10:25 PM
  #34
jmudreamvette's Avatar
jmudreamvette
On run flats I'm runing 11.76 @ 121 in Florida on a mild day. A6 stock 2.73 gear, Vararam, Ported TB & intake, tune Z06 manfolds,cats with NPP out back. My Best 60ft is 1.84 @ Brandenton racway. With a gear 3.42 I should be @ 11.3 -11.4. LS3 runs good. Better 60 ft times better 1/4mile times.Dynoed @405hp 403TQ-Dynojet.
Old Apr 3, 2009 | 11:47 PM
  #35
LS1LT1's Avatar
LS1LT1
Old Apr 7, 2009 | 03:02 PM
  #36
05 silver c6
LOCKSHED
I do not have a slip with me but I will check tomorrow. BTW-With TC on did'nt the car bog? I will give it a try next time out.
To the OP... Sorry about the hijack!
Old May 10, 2009 | 04:38 AM
  #37
lockshed's Avatar
lockshed
LOCKSHED
Car never bogged. A friend watching said I spun from the start. It still felt good but with DR's, I really think it will go faster but at what cost to my stock rear?
To 1/4 track
Old May 10, 2009 | 07:56 AM
  #38
07 Z51's Avatar
07 Z51
Spin named it, I didn't. I refer to it by "name" so that if the OP wants to search for the thread, he'll find it.
Siffert - to make it easy for you to understand, I'll use a formula:
wider wheels + wider, bigger side wall, r compound tires = more traction than the stock run flats. Do you have a different opinion?
Siffert should be the "S" stirrer. I find most of his posts worthy of printing on Cottonelle..............
Old May 10, 2009 | 08:05 AM
  #39
pmj341's Avatar
pmj341
he does like to stir the pot
BTW I don't see any good, informative articles with data coming from
the people that criticize
Old May 10, 2009 | 12:18 PM
  #40
HOXXOH's Avatar
HOXXOH
I love that mod. The only downside is that it costs that much every time you do it.
The cost to be permanent is much greater.
