A6 and Gear Ratio
Old Apr 4, 2009 | 12:12 AM
  #61
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Originally Posted by SpinMonster
Testing what? That 3 differently set up cars with different mods makes any proof for gear differences? Its not proof; its random comparisons. There are no controlled variables and the cars are way different.
TESTING INVOLVES ONE CAR WITH ONE CHANGE. TAKE THE SAME CAR AND DO A GEAR ONLY SWAP....THEN YOU HAVE PROOF.
The proof is Subfloor. He has used the same car with ALL 3 gear ratios. How many times do you need to hear this?
Well see next week if the weather cooperates if I can get my STOCK HEADS,STOCK GEAR 2.56 with 3600 stall converter in the 10`s with a cam only with bolt ons.
Old Apr 4, 2009 | 12:16 AM
  #62
GETUSUMM's Avatar
GETUSUMM
Old Apr 4, 2009 | 12:20 AM
  #63
SpinMonster's Avatar
SpinMonster
Originally Posted by Tony B4
What proof do you have to show us? Do you have any proof about an A6 car with gears at the track?
I have lots of proof that differnet cams run different times at the track.
We recently had lots of head/cam cars run different time at the track with the same peak power.
We are still looking at your proof that differently modded cars are all the basis for your proof.
I have lots of GEAR proof at tracks but you seem to think gears dont work on your car, yet you have not run a single car with only a gear swap as a comparison.
Old Apr 4, 2009 | 12:21 AM
  #64
C6 DVL's Avatar
C6 DVL
St. Jude Donor '08
Old Apr 4, 2009 | 12:23 AM
  #65
Tony B4's Avatar
Tony B4
St. Jude Donor '08
You like to make jokes and I am a very serious person, but you wouldn`t know that. As I said before, Subfloor is your proof. He has ran all 3 gear ratios in his own car. Again, how many times would you like us to tell you that.
If people don`t agree with your opinions, you make jokes, but really the joke is on you.
Old Apr 4, 2009 | 12:28 AM
  #66
SpinMonster
Originally Posted by Mikeg4572
It just need to be clear for most people gears are not that big of a gain on the A6. Not saying that they dont help. I just dont want people to run out and spend 2k+ for a mod that will not yield them as much as they think. ESPECIALLY for most of us who have less than 500hp.
You know the rediculous part of this is that the argument is what the gains are; a tenth or 2-3 tenths. It is pretty stupid.
Maybe we should meet in the middle....anyone for .15?
Its getting too aggressive. Good luck with the runs and when someone has more streamlines controled variable proof, Im open to hear it.
For a street car I would get a 2800 w/3.42's.
  #67
SpinMonster
The gears were the only change?
Old Apr 4, 2009 | 12:43 AM
  #68
SL33PER's Avatar
SL33PER
I will go ahead and say agree with you! .15 is what I would expect at best. At least we can meet in the middle on that one. There are always going to be variations either way. I dont want to argue anymore than we already have as we all have the same goal in mind......To run as quick as we can
At least we all keep eachother in check!
Old Apr 4, 2009 | 12:50 AM
  #69
HOXXOH's Avatar
HOXXOH
Will somebody with a manual please try this test.
Make one or more runs as you normally would for the baseline.
Then make a run starting in 2nd gear instead of first.
Then try one by starting in 3rd gear. You'll need to slip the clutch to get started and not go WOT real early.
Then even try one in 4th gear only.
My guess is that the MPH will be nearly identical, but the ET will be seriously different.
That'd be a test of everything being identical except gearing.
I don't know if you could program an auto to do this, but if you could, then someone with a converter and someone without a converter would put this baby to bed once and for all.
Old Apr 4, 2009 | 01:00 AM
  #70
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Do you know what the really sad thing about all of this is? It's that Mike and I were actually considering doing the swap on back to back days in Sacramento just to prove our point but the whole thing would be nothing more than a waste of time because Spin'll just start crying about how we had more gas in the tank on one day vs. the next or the track prep was different or some other B.S. reason just to try and support his B.S. theory.
Tony has timeslips, Ron Graham has timeslips, Mike has timeslips and I have timeslips to back up what we're saying. And what exactly have you offered up Spin? Apart from one or two mentions of ETs from other drivers (most of which weren't even Corvettes for that matter) and some lame rhetoric you haven't really given anybody here much of a reason to believe you and to use the phrase "controlled" and "drag racing" in the same paragraph (let alone even the same thread) is idiotic at best.
Anybody who's ever drag raced more than once knows that there is absolutely no such thing as a "controlled variable", so at best comparing similar cars with similar mods in similar conditions is the best that all someone can hope for and that's what I did in my other thread regarding this subject.
Wow, the next thing you're probably gonna tell me is that the SpinFast intake should be good for a full 3/10ths at the track....Oh wait, we've already been down this road before haven't we?
Old Apr 4, 2009 | 01:12 AM
  #71
bosco 08's Avatar
bosco 08
wow now i'm really confused.
Old Apr 4, 2009 | 01:15 AM
  #72
siffert's Avatar
siffert
I am running that same Fast intake this week or next depending on
weather, so I'll give the full report on that claimed 3/10's from a no cam added car. So far from street testing/logging, it has not done much. It does sound a bit throatier than stock though with the hood up.
btw-it turns out that the 3/10's claimed down that road before was a Fast ported and installed by Cartek without a firewall mod.
Old Apr 4, 2009 | 01:24 AM
  #73
SpinMonster
I'm being too aggressive and appologize. I'm not belittling your efforts. You do more than the majority and I respect that. A same car swap would make the point for sure. I PM'ed Mike to help set up his car and he passed. I was trying too.
I'll extend the same offer to you. If we colaborated and found the answer together then there would be no doubt if both sides had input as to controling the variables that can be controlled. My labor is free.
No need for personal attacks. I tried saying that to TonyB4 in a PM to make peace. In my defense I never got personal with these kinds of attacks because someone disagrees with me. I went back and saw the deterioration progression. You say 1 tenth and I say 2-3 at this power level and thats the basis for all this hostility? Agree to disagree. If there is a middle ground, its in the overlap of the two mods in question. Would gears alone get 3 tenths? If its 1.67 tenths are we both wrong? Its gone too far and you may want to look at the way the personal smacks increased as the thread went on because someone disagrees. While its obvious some people in this thread only respond that way, you and I dont usually do that so lets get it back to being civil.
I guess you all know I feel strongly about gears. I've driven the A6 with 3.42's and like them especially on the street. I was a track junkie for 20 years. I dont track a 50k car becuase I have hit the wall enough times to know its 'not worth it'. For this reason I dont do only 1/4 mile mods. My car is basically set up for the 1/4. The only change would be to swap my MT ET street 305/35/18's (everyday tire for me) for a 305/45/18 to allow up to a 140 trap speed and give me some side wall. The rest can take it....lev 4 trans, stage 3 diff, lots of power and a twin disc clutch. If it makes a car faster 0-60, 0-100 then I see it as important. Note I go from a dig. Knowing my mods you guess what it would do with a good driver which I am not.
I look forward to your new runs and seeing the results and how it plays into learning something. When I see something that proves me wrong, I admit it. I was wrong about L92 heads and admitted it. Can I be wrong? Yes. Maybe your next few runs will get me there. I hope that at least opens the door to respect.
Okie, I have 50 or so PM's from people seeking free info and 4 free e-mail tunes (friendship seeking gestures involving no money for me) to get to, including Siffert's tune above who is looking to discredit my intake manifold mods and porting. Feel the love.
Old Apr 4, 2009 | 07:13 AM
  #74
dennis50nj's Avatar
dennis50nj
do you even read, its about the a6 and gears
Old Apr 4, 2009 | 07:21 AM
  #75
dennis50nj's Avatar
dennis50nj
Originally Posted by siffert
Drag Times DA does not make predictions. It takes the weather data for
a given track and a given date/time and applies the 4 components that make up DA (temp, altitude, barometer and humidity) and gives a scientific number for what has already occured. The fact that Drag Times DA (along with every other online web site and cable/TV broadcast weather) does not match to your "Atco Boys weather station" does not mean it is inaccurate.
yes this is partly true, but to read the info correctly it has to be done at the track, not at someones house on there back porch in the shade it has to be done at the track surface, all the heat from some of the big tracks that have a 1/2 sq mile of asphalt generate a lot of heat, then wind speed is a factor, a fifth element. one day you will learn grasshopper, just admit it your wrong, busted
Old Apr 4, 2009 | 07:58 AM
  #76
JT Metal's Avatar
JT Metal
St. Jude Donor '12-'13
I"ve called yank in the past. LS motors push thier power higher in the RPM band. So with that said. An old stye 350 & LT1 motor would use less converter than an LS based motor. But because of the STR in a yank they (Yank) and every one I've talked to said use a 3600 for a D.D. 4000 for a W.W. Both would require better then factory tires to take advantage of hard launches. Gearing doe's play a role in it. With a 3.42 being the minimum in an a4. So if an a6 with a 2.56 acts like a a4 with a 3.73/3.90. I think you'd be one happy camper. JMHO-Buy Yank!!!!
Old Apr 4, 2009 | 09:13 AM
  #77
siffert's Avatar
siffert
I never had a problem admittied being wrong, have you? In this instance, Drag Times DA has given correct DA info for every track
folks have run (save for some minor varience with altitude vs Google Earth). Except, quite oddly, for your deep negative DA track called Atco.
You cannot put a handheld weather station directly in the sun and/or clouds on the track surface, you will get incorrect readings all the time. For measuring track surface temp, you use an infra red temperature sensor. Every handheld weather station instruction manual will tell you to use that instrument in the shade ONLY.
For further details on how to use a handhled weather station correctly at the track, do contact Ranger. Basically he puts his Kestrel in an upside down 5 gallon bucket with the top cut off and out of direct sun shining down on it. Thus, it is now quite apparent why those Atco DA readings of yours are so out of whack with the rest of the world!
To A6 and Gear Ratio
Old Apr 4, 2009 | 09:44 AM
  #78
JT Metal's Avatar
JT Metal
As J.J. from "GOOD TIMES" would say DYNOMITE
Old Apr 4, 2009 | 09:51 AM
  #79
HITMAN99's Avatar
HITMAN99
OK, it should be pretty easy to launch the A6 in second gear. Next time I am at the track (my once a year excursion) I will give it a try.
Equivalent of a 'Glide. That's what I had in my '59.
Old Apr 4, 2009 | 01:04 PM
  #80
beefcake's Avatar
beefcake
well, i just did the 3.42's yesterday in my a6 and the xlr converter from the cadillac,
it's a 10.5" dual disc, haven't been able to get on it yet because i'm not tuned for the gear, plus they need to be heat cycled a couple of times
plan on hitting livernois this week for a tune,
i can tell you even though the highway is higher rpms, it's nothing compared to running 4.10's or 4.30's in my mustangs turning 2600-2700
just driving back from rpm yesterday, i was very happy with 6th gear now, before in 70 with 600rwhp the car was still a turd, now it accelerates nice
i personally don't think a big stall is needed with the gear, i pulled a 1.76 with 18" dr's at the track, with the 3.42, i figure 1.6's at least with a pretty much stock stall, maybe better, who knows
