Navigation unit install ?
Old Apr 8, 2009 | 12:46 PM
dwiemers's Avatar
dwiemers
Default Navigation unit install ?
Need help! I've got a 2008 LT1 and I want to put a navi from another Vette in it. How easy is this? Can I just pull out the factory stereo and put this in? Any suggestions would help!
Thanks!
Old Apr 8, 2009 | 01:31 PM
FRANKENSTEIN4x42000's Avatar
FRANKENSTEIN4x42000
just did mine, piece of cake take off the console, 4 screws if i remember right and swap the units, the only thing is where to mount the antenna, there is a post about it when i was looking for it. and you are done.
Old Apr 8, 2009 | 03:01 PM
dwiemers's Avatar
dwiemers
So, you don't have to have the bose system or anything to make it work? that was my main concern...if it's plug and play i'm all over it....
Also, is there better models with diff years? some play dvd's and some don't or something? or should I not worry about what year as long as it's C6 stock stuff...
Thx again!
Old Apr 8, 2009 | 05:51 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
If you don't have Bose your in for quite a chore. With Bose it's plug and play. 05's had older programming so you would want to upgrade the programming. 06 to 08 is pretty much the same unless you have steering wheel controls then late 07 and 08 is what you would need. 09 incorporated Blue-Tooth.
Old Apr 8, 2009 | 10:07 PM
dwiemers's Avatar
dwiemers
Good deal, so I'm going to shoot for an 06-08, and it CAN be done in a coupe without Bose but it just takes a little more work.....what is the extra work that needs to be done? Splicing some wires or something?
Old Apr 8, 2009 | 10:15 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
St. Jude Donor '17
It going to be lot more than a little work. Check in the stereo forum do a search probably on NAV and you should find several threads on what is involved.
Old May 29, 2009 | 08:15 AM
MCSSLT1's Avatar
MCSSLT1
I was going to put up a new post but this one looks like it answers my question. As long as the car has the Bose Premium Sound System it is plug and play? It seems that people are selling the factory Nav units for $500-700.
Old Jun 22, 2010 | 10:45 PM
rstingray's Avatar
rstingray
4th Gear
I had installed a factory Nav unit into my 2005 and documented the install here: http://www.skyhighphotos.net/CorvetteNAV.htm
Hopefully, that answers any questions you may have.
Old Jul 30, 2017 | 08:16 PM
rik8020's Avatar
rik8020
Cruising
Default Navigation Installation GPS Signal
Installed navigation in my 08 coupe, everything went fine but today put in the navigation disk. Typed in a destination from my place to a nearby location in SoCal and the trip was originating from Washington DC. The map indicator was moving as I drove and the voice kept giving me directions not related to my trip.
I tried to calibrate the location and I got the indicator to show my house as location. The GP indicator on the screen has a red line slashed through it. I am thinking it needs to be turned on somehow. Any help?
Old Jul 30, 2017 | 09:42 PM
Dcasole's Avatar
Dcasole
I answered your email
Dave
To Navigation unit install ?
