Service active handling system
Old Apr 8, 2009 | 07:39 PM
NavyC4S's Avatar
NavyC4S
St. Jude Donor '09
Default Service active handling system
What did I break...?
I've had 450+ rwhp on my 05 Z51 for over a year now and just recently upgraded to a Spec twin plate clutch.
I noticed an intermittent service active handling message when turning off traction control.
Currently, when I start the car, I get a service engine soon and service active handling message immediately.
I hear a rattle when I go over bumps in the passenger rear quarter.
What's wrong?
Old Apr 8, 2009 | 07:47 PM
Z11409's Avatar
Z11409
read codes-might be just a wheel speed sensor
Old Apr 8, 2009 | 08:14 PM
NavyC4S's Avatar
NavyC4S
St. Jude Donor '09
could it have broken off or not been put back on?
Old Apr 8, 2009 | 08:18 PM
Sparo2's Avatar
Sparo2
It could be a lot of things. Best thing to do is get it scanned. I would do it for you if you were near by. Just get those codes read. They'll point you in the right direction.
Old Apr 8, 2009 | 08:58 PM
NavyC4S's Avatar
NavyC4S
St. Jude Donor '09
thanks for the help, I'll get it read
Old Apr 8, 2009 | 09:45 PM
Paulkr's Avatar
Paulkr
I have the same problem since putting in a spec clutch except mine is more intermitent. Onec the car is shut off the warning goes away. I have a diablo sport reader but it does not tell me, cause the warning goes away.
Old Apr 9, 2009 | 06:03 PM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
You need a Tech II scanner to read the codes on this since they're stored in the EBCM and not the PCM.
I recently had this same issue so I might be able to help you out. Send me a PM if you like and I'll explain how I resolved it.
Christopher
Old Apr 9, 2009 | 09:06 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Why not explain it on here to help the rest of us understand whats happening?
BC
Old Apr 9, 2009 | 09:14 PM
jmt1669's Avatar
jmt1669
St. Jude Donor '11
I was having the same problem. Try this link, hope it helps:
http://forums.corvetteforum.com/c6-t...ing-issue.html
Good luck
Old Apr 10, 2009 | 12:57 PM
thesubfloor
BC
I’m not sure how much (if any) of this will help, but this is what happened to me and how I ended up getting it resolved.
After swapping engines in my car recently (I put in an LS7) I immediately got the warning messages for all three systems (ABS, AH & TC) on my DIC whenever the car was running. I took the car to a local dealership and because the Parts Manager was a friend he brought out a Tech II scanner to the parking lot (so he didn’t have to charge me anything) to see what codes got set in the EBCM (Electronic Brake Control Module, which is essentially your ABS unit).
According to the scanner both the front right and rear right vehicle speed sensors were showing a problem and because of that, whenever he tried to clear the codes they immediately got set again. Figuring that there must have been a short somewhere in the system, I took the car home and decided to try troubleshooting the wiring.
I did a quick visual of the wiring for the speed sensors and immediately discovered that I had accidentally pinched part of the harness behind the ABS bracket but when I examined the wiring more closely I didn’t see any breaks or damage so I kept investigating.
By using a multimeter and disconnecting the harness from the EBCM (I can e-mail you the pinout diagram if you’d like) I was able to test all four wheel sensors. How I did this was by inserting the probes into the correct place on the harness (there’s eight wires in total, two for each wheel) and then spinning each wheel and then watching the multimeter. As it turns out each wheel sensor emits a small amount of DC voltage so whenever I spun a wheel and saw the multimeter reading change I was able to determine that the wiring was intact as was the wheel sensor.
After seeing that there didn’t appear to be any shorts in the wiring and all four sensors appeared to be working correctly I was rather dejected and put everything back together figuring that the next step would be to take it to the dealership and get ready for a “time and materials” job where they charge you by the hour (which would have been out of pocket since it wasn’t a warranty-covered problem) and there’s no guarantee in the end of even finding the problem. When I first started up the car the lights stayed on as expected but after about 5 seconds they turned off and ever since then my TC, AH and ABS have all been working fine.
I’m not exactly sure what ended up fixing the actual problem but my guess is that either the pinched harness was somehow causing a short or disconnecting and reconnecting the harness from the EBCM somehow made for a better connection.
You may not end up being as lucky as I was, but hopefully the diagnosis steps I outline above should at least allow you to verify that all four sensors are working properly which would at least eliminate that as a potential cause if you end up having to start looking elsewhere for the problem or ultimately take it to the dealership.
Hope this helps,
Christopher
Old Apr 11, 2009 | 10:59 PM
kastle875's Avatar
kastle875
Not sure if this helps or not but I had the SAH light on mine...at <2K miles...turned out to be a break pressure sensor...an $80 part...after that was replaced and system bled (dealer did it) the message went away and has been fine since.
Good luck!
- Kastle
Old Apr 12, 2009 | 11:54 AM
f355c5's Avatar
f355c5
Get used to it. I have that pop up all the time. I ignore it and the next day it is gone. The corvette mystique. GM at its finest.
Old Apr 12, 2009 | 07:31 PM
NavyC4S's Avatar
NavyC4S
St. Jude Donor '09
It's gone...WTF! I didn't change anything and it doesn't even come up on Competitive Driving Mode.
Old Apr 19, 2009 | 09:10 PM
NavyC4S's Avatar
NavyC4S
St. Jude Donor '09
Cleaned the MAF and removed the screen... PROBLEM SOLVED
Old Jun 20, 2009 | 09:33 AM
SgtRod's Avatar
SgtRod
Cleaned the MAF and it fixed the Active handling message?? WTF... I have this Active Handling problem and its making me want to get rid of my corvette. Its been going on for like 7ooo miles already and dealer is kind of lost.
I got headers put in and thats when it started. Since then I can't enjoy WOT over 5k rpm or AH comes on. Did you have your intake and TB ported Navyc4s?
Old Jun 22, 2009 | 01:57 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Right now,,Im out of the country on business. When I return,,,Im going to clean each wheel speed sensor connection, clean the MAF and check all the chassis grounds.
I will let you know if that makes any differences.
BC
Old Jun 22, 2009 | 02:09 PM
TCKT B8's Avatar
TCKT B8
St. Jude Donor '09 & '11
Default Service Active Handlling System
I had a bout with this for a while a few months ago. The dealer reflashed the computer - that didn't do it. They put a data monitor in the car and I recorded the incident several times. I have no idea if that helped them locate the problem or not, but they finally fixed the problem on my third trip back for service and I haven't seen the message or had a problem since. What did they do? They went through the car and tightened ground connections. Hope this helps someone else.
Old Jun 27, 2009 | 09:09 AM
NavyC4S's Avatar
NavyC4S
St. Jude Donor '09
yes and yes...
Old Jun 29, 2009 | 12:30 PM
SgtRod's Avatar
SgtRod
Wow Navy brother,
If you found the cause for the AH malfunction in the MAF then Im in deep crap. I have a similar issue with my AH and am just about to give up. Im about to click my heals together and say I wish it goes away.. I wish it goes away!
Glad to hear of another Vette owner that solved this on his car. I'll have to try it.
Rod
To Service active handling system
