Engine noise help!!
Old Apr 9, 2009 | 04:23 PM
sombra760's Avatar
sombra760
Default Engine noise help!!
I have an 08 vette with ls3 engine and it has 12k miles..I just noticed a knocking noise from the engine when i start the car in the morning.The noise dissapears after a few minutes....any comments or suggestions of what could be the cause of this noise?
Old Apr 9, 2009 | 05:30 PM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
Did you just have the oil changed???
Old Apr 9, 2009 | 06:05 PM
sombra760's Avatar
sombra760
nop
Old Apr 9, 2009 | 06:29 PM
pmj341's Avatar
pmj341
So what did you do??
something making noise, goes away when it warms up?
oil pressure normal?
sound like you need to return to the dealer and have them check it.
wrong (no check valve) oil filter will cause a noise at start up until oil press build up,
can you tell us more about the noise??
Old Apr 9, 2009 | 07:29 PM
calemasters's Avatar
calemasters
Could this be hydraulic valve lifter noise.
Old Apr 9, 2009 | 07:44 PM
VET4LES's Avatar
VET4LES
If it is it's normal.
Old Apr 10, 2009 | 09:43 AM
lemonademan's Avatar
lemonademan
Have you ever had the oil changed?
Old Apr 10, 2009 | 09:53 AM
JRHAWK9's Avatar
JRHAWK9
exactly what I was thinking...
Old Apr 11, 2009 | 03:47 AM
sombra760's Avatar
sombra760
Yes, I already changed the oil...
i am going to change the oil this week even though the computer says that the oil still has 54% life
Old Apr 11, 2009 | 04:06 AM
c6 batmobile's Avatar
c6 batmobile
It sounds like a lifter. Some times they dont get enough oil on start up because its too thick. Are you using the recommended weight? Are you parking it somewhere its cold like outside?
Old Apr 11, 2009 | 01:00 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Lifter noise is more of a ticking sound, not a knock. And it should disappear within seconds not minutes of starting.
Does the knocking sound louder under load before it disappears? I'm thinking piston slap until parts expand enough (from heat) to quiet it.
Old Apr 11, 2009 | 02:06 PM
sombra760's Avatar
sombra760
it doesnt sound louder under load, but if i press the gas the noise dissapears...
Old Apr 11, 2009 | 02:14 PM
AirBusPilot's Avatar
AirBusPilot
What kind of oil pressure do you have when hot and cold (idle)?
Old Apr 11, 2009 | 02:18 PM
TinSecondRice's Avatar
TinSecondRice
St. Jude Donor '08-'11
Is it more of a knock or a tick?
knock
http://www.youtube.com/watch?v=-Gq9G...eature=related
tick
http://www.youtube.com/watch?v=DRqhk...eature=related
Old Apr 11, 2009 | 03:27 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Most likely piston slap. Most dealers will tell you its normal during cold start up.
Is your car under warranty????
If so, at least get it documented and see what the dealer says about it. Once it documented, if theres a problem in the future, you will have a better chance of some sort of assistance (IF GM STILL EXIST IN THE FUTURE!!!:leaving
Old Apr 11, 2009 | 04:45 PM
Greenvetter's Avatar
Greenvetter
Got to the dealer and get it documented. I did. My 05 sounds like a box of rocks when it's cold and then for a while after when lifting the throttle between shifts.
The dealer told me it was due to the short skirt pistions. Mine goes away after the car is warmed up too. Not confidence inspiring to say the least. I thought I had a spun bearing or a connecting rod trying to set itself free from the block.
Old Dec 10, 2010 | 10:30 AM
Kurac's Avatar
Kurac
Interesting.
My daily driver is a 2005 GTO with the A4. I bought the car with only 4K miles. I currently have 81K miles. The car is stock, save for a Lingenfelter CAI. I do all of the oil changes myself and have used nothing but Mobil One 5W30 Full Synthetic, changed every 5K miles. I have a 100 mile round trip commute every day. All highway miles.
Last year I heard a loud knocking sound coming from the LS2 upon cold start up. It went away fairly quickly, like in 5 seconds. Then I never heard it again. Fast forward to this past Monday, temps were in the 30's and the knocking came back. Again it only lasted about 5 seconds and quickly went away as the car started to warm up. I have not heard it since, and air temps have been in the 30's.
Is this normal?
Old Dec 10, 2010 | 12:18 PM
AirBusPilot
Originally Posted by Ladimer
Interesting.
Is this normal?
Definitely not normal. Get an oil analysis done asap!
To Engine noise help!!
