I am facing a problem with my friend C6. We had a leak in the transmission oil cooler, the one located in the radiator.
It’s all been done and fixed but the problem is:
How to refill the transmission oil.
How many liters it needs
The car is a 06 – LS2. And it’s AUTO
you have to check it in the back under the car, you fill it then run it until it gets warm all gears check temp gauge, then pull the fill plug and if fluid comes out your good, if not add more and repeat process
