Brake pad replacement help!!!!
Old Apr 11, 2009 | 05:14 PM
IMLEVNU's Avatar
IMLEVNU
Default Brake pad replacement help!!!!
Ok guys i have an 07 z06 and i am trying to unscrew the pins on the front calipers. Why are they not comming? Is there certain instructions? Any help would be appreciated.
Old Apr 11, 2009 | 05:44 PM
johnodrake's Avatar
johnodrake
Moderator
The pins are notoriously difficult at times to remove. Short of removing the caliper, I don't know what to do except maybe try an impact wrench..... If you remove the caliper, you can soak the pin in WD-40 or Liquid Wrench. Mike Golding (Corvette Pilot) (mike@thepowdercoater.com) may have some ideas.
Old Apr 11, 2009 | 10:20 PM
Mr. Motion's Avatar
Mr. Motion
I am not familiar with Z06 brakes, but with regular C6s, you have to use two wrenches - one for the pin bolt and the other for the inside collar. Otherwise, the pin will just spin.
To Brake pad replacement help!!!!
