how long would this last?
Old Apr 13, 2009 | 02:02 AM
Freaked Ls3's Avatar
Freaked Ls3
Default how long would this last?
100% stock car besides A&A kit and ARH headers pushing 8 psi and has 600rwhp but now wanting to do meth and up the boost to 12psi, how long do you think this will last?
Old Apr 13, 2009 | 02:20 AM
BornSUPERCHARGED's Avatar
BornSUPERCHARGED
I'm not sure how long it would last, but have you considered a boost controller and keeping your boost lower until you need it, then increasing it at that point in time? I mean, driving around with your boost at 12psi might not be the best idea on a stock bottom end engine. I know Ed will chime in and he is 10000x more knowledgeable than I am (I don't know ****).
Or, have you considered a 175 shot?
Old Apr 13, 2009 | 02:45 AM
c6 batmobile's Avatar
c6 batmobile
I would guess not a real long time if you drive it hard. 12 psi is a lot its even more on a stock bottom end.
Old Apr 13, 2009 | 01:43 PM
Freaked Ls3
im going to go up to 10psi and meth it with a cam. if it blows im going to just do a forge swap.
Old Apr 13, 2009 | 02:18 PM
chsmith112's Avatar
chsmith112
It should be any more strain if you drive it normal. But if you push it constantly then yeah it won't last nearly as long. Cause you don't see boost until like 2500 rpm anyway right?
Old Apr 13, 2009 | 02:32 PM
Freaked Ls3
im at full boost at about 3800-4000 rpm. but i start boosting at 2300rpm.
Old Apr 13, 2009 | 10:50 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Erm, no you are not... This isn't a turbo; your Centrifugal blower only reaches maximum boost the second your engine hits the rev limiter if you make 10PSI at 6500rpm you would be lucky to see 5 by 4000...
Old Apr 13, 2009 | 11:06 PM
3 Z06ZR1's Avatar
3 Z06ZR1
He's right, but when your @4000 and boost is increasing itself as quickly as you can say "Ding" Plus your boosting when the BOV closes but even with it open it still is better than any N/A intake. As I have more rwtq at 2500 or even less than it did at any RPM stock!
So with the 390's I hit full boost quickly and with quick smooth shifts,
These Centri's are deadly fast! They push alot of air!
To how long would this last?
