i had cartek install the lingenfelter launch control and all i can say is WOW....much easier to launch and works like a charm! cant wait to get back to the track and get those 60 fts down!!!
The "Launch Control" Box from Lingenfelter doesn't help with traction control type issues. It's simply and literally a two-step. That's the real drag racing term for this unit.
It's good for two things:
1) Consistency @ the track
2) BREAKING PARTS
I almost always snap a rear-end, axle, or tranny when leaving on my two-step @ 2400 RPMS and 3 Lbs of boost.
Definitely a great tool for drag racers who are looking for consistency - but be ready to break a few parts! You'll leave HARD with this little piece (assuming you also have the tires to go along with it).
I bought mine through Hinsons SuperCars (supporting vendor here) for about $260.... (Someone had asked about the price but I don't think anyone has answered yet)
yea i dont know what your doing or how your driving but mine leave much easier, i did this to try and stop breaking parts.....if you just dump the clutch then of course your car will be pushed off the track
2) BREAKING PARTS
Isn't the unit multi adjustable? Can't one set it up to not allow too high (or low) of an RPM at clutch release?
Yes the original poster had actually answered it here:
Wow! I didn't even know something like that existed.
Anyway, If I get this right, this interceptor cuts out the spark, but allows raw fuel into the cylinders? Are you concerned with cylinder wash-down at all? Forget the cats; this has to be murder on the cylinder walls.
Am I missing something here? Excuse my ignorance please.
From: Greater Detroit Metro MI, when I'm not travelling.
Rick
It allows a normal fuel charge into the cylinders, which is far from flooding the engine; I wouldn't worry too much about that; the ECU dumps raw fuel into the cylinders on deceleration as-is even on a stock car (that's what causes the deceleration burble)
Are you sure about that? I always thought the ECU shot down fuel to near zero on decel.
Also, the burble you speak of, from my experience, is caused by small air leaks somewhere in the exhaust system. Real bad leaks cause horrible backfires.
I don't know, maybe I'm all wrong.
My understanding is that the ECU allows a small amount of fuel to be injected into the engine during deceleration to help cool the cylinders down. This fuel is not ignited so when it makes it into the exhaust pipes it can ignite and make that burbling sound.
*ALL* corvettes burble on decel, but few corvettes have exhaust leaks (I know mine doesn't; I installed the exhaust myself); you can't hear it very well on a stock one, but as soon as you put some high flow cats and a loud exhast, it becomes obvious...
From: NJ..."the way I saw it, everyone takes a beating sometimes."
Rick
From LPE's website.
Warnings for use of this product-
Because the LNC-002 acts by disabling spark to individual cylinders, not by disabling fuel like a production RPM limiters it is not meant for use on the street or for use on cars equipped with catalytic converters. The LNC-002 is only for use on race vehicles on the race track. Failure to follow these precautions will result in premature catalyst failure. DO NOT operate the engine with the LNC-002 active for extended periods of time. Because of the raw fuel entering the exhaust, a risk of backfiring exists if you do so.
Originally Posted by PowerLabs
Incidentally I think I may buy one of these and do a proper PowerLabs write up on it with lots of pictures and video
I'd like to hear some more info on this and how difficult and/or accurate the adjustments are. This doesn't require any tuning, correct? Everything can be done from the controller?
Originally Posted by k0bun
From LPE's website.
Appearently no tuning is required. There are a few videos on Youtube of GTOs with it. Seems to be hit or miss/ some people like it and think it helps, some people said it didn't help. I figure it is cheap enough that I can find out for myself.
The fuel that goes into the engine on deceleration is essentially just idle fueling. All corvettes, when they meet a set criteria, shut off all fueling and spark to keep a large amount of raw fuel from destroying the cats. You're right, this is what causes the burble on deceleration at lower rpms. I don't like the sound, so on my car I changed the parameters on the DFCO (Deceleration Fuel Cut Off) so that all spark and fueling is shut of the instant I lift my foot. You can watch it on the wideband, it will read "LEAN" and then "AIR" on my PLX. It gets rid of the burble. The only drawback, I guess, is when I get back in the gas after letting off at a high rpm, but only at higher rpms, there is a slight "pop" when fueling restarts.
Originally Posted by 2000C-5
Launch Control is being offered on the new Camaro and will be on the 2010 Corvettes. Here is a video of GM explaining it.
Yes. It has also come stock in the Mitsubishi Evolution cars for years, its been stock in the Cobalt SS since 2007, I had it on my 2005 Subaru STI, etc etc... This is nothing new.
Being able to install it on a Corvette is the novelty... The fact that a 2010 'Vette has it doesn't do me much good since it can't be retrofitted
That is true. The downside to turning it off, I am told, is that DFCO serves to cool the cylinder down between shifts; most tuners won't turn it off.
I don't know how much of a difference it makes in the real world, but its something to think about.
Personally, I love the sound it makes, btw... Making my C6Z06 mufflers automatically close when I let off the throttle eliminated the sound, and now I miss it...
I think he either got rained out or had some scheduling difficulties and didn't make the track that night. He had a track rental day get rained out today as well. He'll hopefully be testing it out sometime next week though.
Oh, I know it's nothing new. Although it is new to the vette. This was just meant as an FYI for those that didn't know it was coming in the vette. I didn't know the Cobalt had it.
It isn't for cooling the cylinders. It is strictly to keep from damaging the cats with raw fuel. You don't turn it off. Just the opposite. You make it come on sooner than it does in a stock application. If you turned it off, your cats would be short lived.
Theoretical situation: You and an '04 Cobra just did something illegal on the interstate and you decelerated from about 150 mph in 5th gear without using the brakes, if not for DFCO cutting off the fuel, you would be putting raw fuel directly into the cats for a long period of time. Enough raw fuel in a converter that is already over 1000 degrees will ignite and can melt the catalyst.
Well, I knew fuel was drastically cut down on decel. That doesn't answer my question though. Aren't the people running this Launch Control gizmo concerned with cylinder wash down? Depending on the jerk controlling the christmas tree, it takes 2 to 5 seconds to go. That's a long time to have your engine revved up to 4k+ RPMs with raw fuel going through the cylinders, washing away the lubricating oil.
Anyway, I want to understand this a little more. Obviously, if there is no combustion, the engine stops. So, how does this controller keep the engine running without a spark? Does it fire the plugs every other cycle?
Why is it the opposite for COT (Cat over temp)? COT adds fuel to cool the cats if they get too hot from that WOT burst to 150 mph.
