St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
One possibility . . . you may have a defective Exterior Door Handle Switch.
You can test it by replacing it with the switch from the passenger door - very easy to remove (2 phillips screws).
If it works properly, you simply replace the switch.
