From: Greater Detroit Metro MI, when I'm not travelling.
Brake pad suggestions?
Looks like after 20K miles my brake pads are just about done. I'm looking for another set of pads for my C6 Z-51, supercharged car; its a daily driver so initial bite is very important, and excessive noise and dusting are not acceptable compromises. The factory pads were OK for me, so I am looking for something a bit more agressive, but not a track pad (I'll swap pads at the track if I have to).
Rotors wise I will run the Z-51 rotors for a little while longer and then swap over to some two piece rotors. I already run stainless steel brake lines and Motul 600 fluid.
What do you suggest? I had a great experience with Carbotechs in 2 different cars and am considering running a set on the 'Vette, but I want to hear some more opinions first...
The Carbotech Bobcats are a good pad that I'm currently running. I've also run Performance Friction pads, but they were race pads. The were absolutely violent! I mean that in a good way.
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser, and has won multiple SCCA Solo 2 and Prosolo National Championships. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. Bobcat 1521™ compound has also been found to extend the life of your rotors 2-3 times. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
Is that because you make better track pads? or Would the performance deteriorate below that of stock on the track? The question is asked in the context of a car that is primarily street with maybe 2 HPDE a year.
Bobcat is their street pad, Panther is their track pad. I'm sure they have others, but those are the two I'm aware of.
Just put some Hawk HPS pads on two days ago and I like them already. Doing an HPDE in a few weeks. We'll see how they do but I'm expecting good results. Front and rears for ~$180 from hawk pads direct.
I have these (#1521) on my Brembo Gran Turismo's and they are great. No fade , very low dust, and tremendous stopping power.
