automatic transmission problem
Old Apr 16, 2009 | 09:07 AM
vette yellow's Avatar
vette yellow
6th Gear
Default automatic transmission problem
2005 /22000 miles
Yestrday I was out for a drive and in overdrive the tranny just kicked out of gear . It will hold in first and second but in third and overdrive it just spins free . In these gears it will engage if I really romp on it.
Does this sound like a computer problem or what? No code came up.
thanks Duane
Old Apr 16, 2009 | 11:47 AM
c6 batmobile's Avatar
c6 batmobile
could be your torque conveter letting go or your tranny. If there is no codes or CEL then it indicates something mechanical not related to the computer.
Old Apr 16, 2009 | 12:22 PM
TinSecondRice's Avatar
TinSecondRice
St. Jude Donor '08-'11
FYI- I had this EXACT same problem. Check your fluid level.
I send off my transmission and converter when this happened in mine, and there was nothing at all wrong with either one.
Old Apr 16, 2009 | 12:52 PM
L82gofast's Avatar
L82gofast
check your fluid level. If its ok, then the 3-4 clutches are probably toast... Had the same thing happen to my truck.....
Old Apr 17, 2009 | 07:31 PM
TinSecondRice
any word?
Old Apr 20, 2009 | 10:20 AM
vette yellow
6th Gear
Thanks for the info will get back when I know more.
Old May 1, 2009 | 04:33 PM
vette yellow
6th Gear
tranny was toast. fixed and back on the road. thanks for the help
Old May 1, 2009 | 08:40 PM
bosco 08's Avatar
bosco 08
that explains a lot, got any details?
To automatic transmission problem
