i want to put different gears in c6 vette. i do not have intentions to run at a track. my question is what gears should i have installed that will give the best results without a drastic
change in gas
You will get a lot of different opinions on that question. I have 4.10s and lost 1-2 mpg at cruise, but got a great seat of the pants feel. If you have an auto, 3.15 or 3.42 is for you. Filling out your profile would help with answers.
From: NJ..."the way I saw it, everyone takes a beating sometimes."
change in gas
mileage. thanks rich
NOT ANOTHER GEAR QUESTION!!!!
What trans do you have? (auto/manual) What year? What suspension option?
If 4.10's are good enough for John and Spin, they'll be good enough.
Your options are 3.42, 3.73, 3.90 and 4.10 ratio. I would ask 2005 A4 owners with autos who added those ratio's, not manual stick shift owners, what their opinions are. My guess is gas mileage would suffer a bit. You could also consider a stall converter.
I have a 2005 a4 auto. If you have the performance 2.73 then you should probably go to 3.15 if you dont want a drastic change but still want more of a kick in the shorts. I went 3.42 and at 65 I run just above 2000 rpm and at 80 its about 2450. If you want some more info just send me a pm and Ill try to answer best I can.
Your options are 3.73, 3.90 and 4.10 ratio. I would ask 2005 A4 owners
Ask Dennis50nj. He has 373`s in a 2005 and he is flying.
