cam sensor code P0340
Old Apr 23, 2009 | 08:57 PM
racerx8's Avatar
racerx8
Default cam sensor code P0340
Has anyone had the P0340 cam sensor code on their Z06?
I also had a couple of undefined codes occur.
The car starts hard, turns over no start, a backfire, stinks, etc. then may start and idle ok.
The car has 2300 miles and I still love it even with this problem.
Thanks,
Joe
Old Apr 23, 2009 | 09:00 PM
07MontRedcp's Avatar
07MontRedcp
Thanks,
Joe
Did this code show up after changing the cam?
BJK
Old Apr 23, 2009 | 09:52 PM
beefcake's Avatar
beefcake
i've had this 2 times
the first time was when my fuel pump fuse blew at wot during a shift
i cleared it and it was fine
the 2nd time was after, installing my new software in the pcm
it forgot the cam i guess, and dan had to use a tech ii to relearn the cam,
usually you will get a misfire code along with it
Old Apr 23, 2009 | 11:20 PM
racerx8's Avatar
racerx8
No cam change, just headers, a tune, T-stat and milled/CNC'd heads. This occured about 300 mi. after the head swap and dyno tune.
Maybe it is a failed sensor and has nothing to do with any of the mods.
Old Apr 24, 2009 | 12:12 AM
07MontRedcp
I saw the LPE GT11 cam in your profile and thought that you may have had the wrong reluctor/cam sensor installed with the swap. It happened to me. That being said, it still sounds like you need a Tech ll relearn as beefcake mentioned or a new cam sensor as the symptoms are very similar to what I experienced.
BJK
Old Apr 24, 2009 | 12:20 AM
SpinMonster's Avatar
SpinMonster
HPtuners can do the relearn.
Try clearing the computer first of the codes.
Old Apr 24, 2009 | 08:16 AM
racerx8's Avatar
racerx8
Hey Spin how are you?
Thanks all, this problem is on my Z06 so I'll call dealer this AM and see what he'll do with it.
Old Apr 24, 2009 | 10:23 AM
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
Fly Spin in, and we'll stay in the Garage Mahal unitl it's fixed...
Old Apr 24, 2009 | 10:06 PM
racerx8's Avatar
racerx8
Fixed Dealer tech found plug to sensor came unplugged, he thought it was never locked in from factory. Easy fix, a new plug end with locking tab installed and she purrs again actually it's a nice growl.
Thanks for the help
Joe
To cam sensor code P0340
