Garage Floors
Old May 1, 2009 | 09:27 PM
Dan Wendling's Avatar
Dan Wendling
Default Garage Floors
Looking for comments on garage floor finishes.
Old May 1, 2009 | 10:04 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
I was going to go with racedeck style tiles but since my garage is small, once the car was in you'd barely see them. Plus they were kind of expensive. I decided on this from MAM. I think it looks good, is easily cleaned(vacuum or broom), and is comfortable as all hell when working under the car. Plus it keeps my tootsies nice and warm when I detail the car in the winter barefoot.
Old May 1, 2009 | 10:18 PM
SLAMMER 2's Avatar
SLAMMER 2
commerical flooring. 4 coats sealer and then buff!
Old May 2, 2009 | 05:43 AM
CPG1962's Avatar
CPG1962
St. Jude Donor '09-'10
Default Go to an industrial supplier!
Not Home depot or Lowes and do any one of several floors such as epoxy or polyurethane top coats with or w/o grit ( you can go from a very fine anti-slip to very coarse). Look up Rustoleum INDUSTRIAL finishes. You need just prep the floor mechanically (with a grit blaster made for doing floors - can be rented) or easier and cheaper - acid etch (sold by Rustoleum). I had sold industrial paints in the past (many years ago) and if done correctly these floors would last 50 years in a consumer environment. It done w/o grit it will look like glass and virtually industructable. I has some of my warehouses done a few years ago and they look just awesome.
To Garage Floors
